Like Tree5Likes
"the engine tuning bible"
Old 03-01-2011, 11:12 AM
  #271
Unhappy
Can,
You guys tell me why this engine is doing this.Yesterday I got my engine running for the 1st time this year,yes it was properly winterized.Started after a little coaxing and it was chilly outside.I waited till temps hit about 180 then took it for a spin,at first it seemed good.Decent smoke all the way to wot.Temp hit about 210 or so and then it started to bog out.This was only in the very first part of the throttle pull,and then seemed fine the rest of the way.But almost every time i came to a stop it would get sluggish in the 1st part of throttle pull,and yet it was idling decent.
Thanks in advance
The fisherman is offline
Old 03-01-2011, 01:04 PM
  #272
Maximo's Avatar
Originally Posted by The fisherman
Can,
Thanks in advance
dirty carb ! very common over winter ! fuel gels up and collects in the fuel passages....
Maximo is offline
Old 03-01-2011, 01:31 PM
  #273
Neal,
What is the cure,I want to get this engine out and ready as a backup,before I put your engine in.Should i just run a few more tanks through,I did put a drop of after run oil in the carb.Will this just go away after another tank or 2 or is there something else i should try.I just got your e-mail I will try the youtube thing hopefully tonite,got boiler issues to deal with right now.
Thanks,
Don
Old 03-01-2011, 01:36 PM
  #274
hambone's Avatar
Neal,
Thanks,
Don
I sent you pm earlier. Call me and i'll walk you through it.
hambone is offline
Old 03-08-2011, 10:05 AM
  #275
teeforb's Avatar
Trader Rating: 94 (100%+)
subscribe
teeforb is offline
Old 04-11-2011, 12:40 PM
  #276
Default toro nero
started breaking in toro tea today first start was a demon to get actually had to lean the needles some following the bible best as i can this motor is my first nova so far seems like a beast
toofless is offline
Old 04-28-2011, 05:29 AM
  #277
Default Tuning question
Hi guys,
I'm not exactly a noobee and can usually help a lot of guys with tuning but this one has got me stumped and was hoping someone could chime in with help.
I have a new OS xzb Speed and I've never had an issue like what I'm experiencing with this engine.
Scenario :-
Hi Speed pass and the engine revs out with not too much smoke and has heaps if not too much power. When I back off the engine almost stalls out and then the idle rises to normal and will idle this way for 20-30 secs.
After idling for 20-30 secs it will take off slightly slower with more visible smoke than say idling for a few seconds.
After idling for 1-10 secs it will take off really quick.
So am I correct in assuming that my hsn or mrn? is maybe too rich still which is causing the idle to almost stall out after a high speed pass ??
If I blip to 1/4 throttle smoothly, idle will drop straight back to normal when I back off.
Trouble is I don't really wanna lean it anymore on top as it as honestly got too much power now. I'm running 30% Nitro and 6mm venturi. Standard head shims.
Any ideas guys??
Edit :
Clutch bearings and clutch is good.
Soapy is offline
Old 05-01-2011, 09:06 AM
  #278
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
Pete Martinez is offline
Old 05-03-2011, 06:57 AM
  #279
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Soapy
Hi guys,
Scenario :-
Any ideas guys??
Edit :
anyone? this is happening to my +4, revs out great then throttle off back to idle then idle is very low then flames out ? what needle is causing this?
aussies1129 is offline
Old 05-03-2011, 05:34 PM
  #280
houston's Avatar
Trader Rating: 96 (100%+)
sounds like over lean top , too rich low
houston is offline
Old 05-09-2011, 11:54 AM
  #281
rustyfingers's Avatar
Big thanks to the OP. This has been a great help for this old newbie.
Thanks,
Dennis
rustyfingers is offline
Old 05-12-2011, 11:52 PM
  #282
i have ago gx7r with the long lsn needle..y observations so far are.. if i lean the lsn so that quarter to full throttle has a light steady stream of smoke the idle to 1/4 is too lean (no power)..if i lean so 0 to 1/4 had smoke and power 1/4 to 3/4 is too rich and lots of smoke hsn seem to only effect the last 1/4 of the rev range (3/4 to full) is this common.. do u lean hsn more to compensate for the lsn richness?
boomtheroom is offline
Old 05-30-2011, 12:33 AM
  #283
LOSI123's Avatar
Trader Rating: 63 (100%+)
LOSI123 is offline
Old 06-15-2011, 10:20 AM
  #284
bucket2772's Avatar
Trader Rating: 15 (100%+)
Default Engine help
I put this in another forum but the more help the better-
Hello all,
My engine us a RB S7, about 5 years old and it runs great when it gets going but if I do not run it for a couple of days, it is hard to get going.I am also having problems with the idele settings (It revs high when jumping and I am not on the trottle) I have taken really good care of it, after run oil, broken it down and cleaned it when not racing it, etc etc.
I do alot of racing but I am just wondring if it is time to get a new motor
bucket2772 is offline
Old 06-15-2011, 01:18 PM
  #285
Lille-bror's Avatar
Hello all,
Hi.
Sounds like it is too lean on the LSN. You can't start it because close to no fuel gets through the carburator. Try 1/4 or 1/2 out on the LSN and see how that works
Always turn the HSN 1/8 out before you put your car on the track for the first time each race/practise day. Then you will start on the rich side no matter the outdoor temp, humidity etc.. After 5 min. or so, you can lean the HSN a little, just untill your fine engine sings on the straight
Lille-bror is offline
