Like Tree5Likes
"the engine tuning bible"
Old 05-08-2010, 09:39 PM
  #211
houston's Avatar
Trader Rating: 96 (100%+)
Originally Posted by mbx5rcr34
guys i need your input here we went for practice yesterday & everything was fine new clutch shoe,spring & cleaned filter , except the jx motor flame-out (half-tank) ,so i tried to richen the top (hsn) & fill it up again after some passes same thing when it rich to half-tank it will flame-out ,i tried new p3 plug same thing,if not half-tank it will flame-out on 1/4 mark
put a new tank in it
go to the ebmods js thread , there are a number of experts on that engine in there
houston is offline
Old 05-08-2010, 09:58 PM
  #212
i just change the tank recently ,i would say 10 tanks already
mbx5rcr34 is offline
Old 05-09-2010, 12:13 AM
  #213
shauncarman's Avatar
Smile
Very Helpful
shauncarman is offline
Old 05-09-2010, 06:52 PM
  #214
Default Tuning help
I just chased a tune all day. I put a new carb on a good running OS v-spec, old one's slide was sticking. It ran great on the starter box, started right up, idled good, good power etc. until it was put on the track. At best it would run great on the straight, i'd coast through the sweeper, then when I got back on it, it gurgled like it was loading up. Re-tuned and it would bog and try to die at half throttle, a couple times it backfired (again it was perfect on the bench). Tried numerous time, same results.
It seemed like it only acted up under load. Other suggested an air leak, it didn't seem like an air leak to me but I was willing to try anything, so I changed fuel lines, tightened carb, pipe etc.
I thought maybe a clutch problem but just pulled it apart and it seems good. Is this maybe a mechanical problem seeing it only happens with the cars wheels on the track?
Any ideas???
triple7s is offline
Old 05-11-2010, 04:07 PM
  #215
houston's Avatar
Any ideas???
make sure you have the proper shimming under the head
houston is offline
Old 05-13-2010, 04:01 AM
  #216
TC3ElectricGuy's Avatar
quick question..
i'm running in an engine axe cobra x1 evo .21
i've done about 2L through the engine now and it's starting to get some serious top end speed.
when tuning this engine i have found myself having to richen the mixture to get a better top end without lean bog (which i have experienced when running this engine in). so i richened the HSN by upto 1/4 turn..
does this seam right with a new engine? is this just the engine wearing in and finding new RPM?
also. when applying open throttle, backing off, then applying open throttle the engine would surge slightly on the 2nd take of... once again, is this just a result of a too rich mixture... both HSN and LSN, and/or the engine wearing in?
at all times the engine has blown blue smoke. with the spit test . spit evaporated after about 6 - 8 secs.
TC3ElectricGuy is offline
Old 05-15-2010, 02:45 PM
  #217
DaveG28's Avatar
Trader Rating: 65 (100%+)
Hi guys,
i'm a bit of an amateur and have accidently adjusted my LSN on my OS speed while adjusting the throttle ballstud position!
As it runs now it's fine once it's off and running, it doesn't stall quickly when sat idling but under initial acceleration it sits for 1-2 seconds before clearing out and accelerating with initially a lot of blue smoke. The HSN is definitely bob on so it is only the LSN that needs adjusting, does it sound too rich or too lean?
DaveG28 is offline
Old 05-16-2010, 05:32 AM
  #218
tkhoo's Avatar
Trader Rating: 45 (98%+)
Originally Posted by DaveG28
Hi guys,
too rich on your LSN. Lean it little by little.
tkhoo is offline
Old 05-16-2010, 06:37 AM
  #219
Cappy's Avatar
Trader Rating: 16 (100%+)
Hi guys,
Try the pinch test
Cappy is offline
Old 05-17-2010, 03:08 PM
  #220
deadmancourt's Avatar
Trader Rating: 11 (92%+)
i have been reading this whole thread to try to weed out the good and bad ideas and have tried them all.....but the 1 i like best is: GET THE MOTOR TO OPERATING TEMP,THEN DO A COUPLE HIGH SPEED RUNS AND LEAN THE HIGH SPEED NEEDLE LITTLE BY LITTLE TILL IT BOGS @ HIGH SPEED THAN RICHEN THE HSN ABOUT 1-2 HOURS DEPENDING ON YOUR OWN LIKEING.....THEN LEAN THE LOW SPEED NEEDLE LITTLE BY LITTLE TILL IT BOGS WHEN THROTTLE IS QUICKLY APPLIED,THEN RICHEN IT ABOUT 1-2 HOURS DEPENDING ON YOUR LIKEING AGAIN....IF YOUR MOTOR IS IDLEING ALITTLE HIGH JUST BACK OFF ON THE IDLE SCREW TILL IT IDLES AND THE CLUTCH IS NOT ENGAGING....AFTER THATS ALL DONE YOUR MOTOR WILL SCREAM! AND IDLE GREAT!
deadmancourt is offline
Old 05-21-2010, 04:28 AM
  #221
........its for my ninja jx21 sorry for the incomplete details,anyway i just realized that i messed-up the MRN setting i just change the o-ring & its acting-up ,but i got it right this time ,so it will idle no-flame-out ............today i just noticed that theres some oil behind the flywheel ,i guess oil leak ,is this the time for replacement ??
Old 05-23-2010, 09:11 AM
  #222
Default losi mach 427 tuning
i need help i cant get this engine tuned right all its broken in just need help tuning it any help would be nice it dies after about 10 seconds of idling and wen i hit the throttle it just dies please help
i have had my aftershock for four years and still dont know how to tune please help
maiden723 is offline
Old 05-24-2010, 08:29 AM
  #223
tkhoo's Avatar
tkhoo is offline
Old 05-24-2010, 05:38 PM
  #224
ok thanks
Old 05-26-2010, 05:50 PM
  #225
tharris1959's Avatar
Originally Posted by TC3ElectricGuy
quick question..
Are you using the cold plug they recommend? I went to a hotter plug, the tune was more consistent
tharris1959 is offline
