-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   Trinity Extech .24 cooling head (https://www.rctech.net/forum/offroad-nitro-engine-forum/442728-trinity-extech-24-cooling-head.html)
hookem34 10-12-2010 12:00 PM
Can anyone tell me what cooling head I can use to replace the one that broke off my Trinity Extech .24 (yep it finally happened :flaming:!)?
Thanks!
ScottyM 10-12-2010 12:07 PM
Thanks!
Sirio or Werks heads will fit not problem.. Other may also, but these will for sure..
hookem34 10-12-2010 01:03 PM
Do I need to use a head from a .24 engine or can I use one from a .21 engine?
marshon50 10-12-2010 01:28 PM
just match the bolt pattern...try the head from your Werks b5....should fit...if it doesn't, it'll be obvious.
ScottyM 10-12-2010 01:55 PM
From a .21 is fine.. The Head bolt pattern is the same on all the Sirio based engines.. An Orion head will work too, .21 or .24..
