Like Tree3Likes
NEW OS 21 XZ-B and Speed XZ-B
Old 06-11-2015, 04:56 PM
  #5146
coneman's Avatar
it's the XZ-B V2 blue head with 22b2 2 needle carb. just wondering how the needles are set.
coneman is offline
Old 06-11-2015, 09:18 PM
  #5147
Frank L's Avatar
Trader Rating: 148 (100%+)
Those settings were for a xz speed with a j2 carb. The carb you are talking about is different. I haven't had one of those so I have no settings for it
Frank L is offline
Old 06-11-2015, 09:30 PM
  #5148
Im thinking it should be pretty close as the J2. the b2 does not have a three needle like the j2 and I dont mess with the third needle anyways on my first Blue Head and it ran like a champ. I am going to leave mine at the factory settings and move from there. I've had OS engines since way back in the 70's with the fsr series airplane engines and it was a bitch getting those to run right. I believe that it was a combination of some different issues like running the wrong prop and 5% nitro instead of 10%. My current .25 SF is about 15 years old and runnings as good as the day I bought it.
stoney452 is offline
Old 06-12-2015, 05:49 PM
  #5149
coneman's Avatar
no worries frank. i was just wondering if anyone had some settings. i'll report back with some settings when i run the engine in.
coneman is offline
Old 06-28-2015, 06:42 PM
  #5150
How much faster is the XZ-b speed spec 2 all black motor compared to the xz-b v2 blue head motor???
1966ss is offline
Old 06-28-2015, 11:52 PM
  #5151
morgoth's Avatar
I don't think it's faster, but smoother and last longer because of the DLC crankshaft.
Mine is 45 litres old, had it pinched twice and only replaced the conrod and bearings at 35 litres. And the engine is still going strong.
It's the best engine I've had hands down.
morgoth is offline
Old 06-30-2015, 07:32 PM
  #5152
I have both and in terms of performance it is very difficult to tell . Roughly performances are identical therefore the XZ-b speed spec 2 is a bit more linear compare to the xz-b v2 blue head motor which is more brutal on the bottom in particular.
whatever your choice both are very good engines for sure.
Desertstorm is offline
Old 07-05-2015, 04:09 PM
  #5153
I'm considering these motors for a on road GT application. Both turn pretty good rpm. 41k I believe.
1966ss is offline
Old 07-14-2015, 08:47 AM
  #5154
dameetz's Avatar
I have an OS Speed XZB (not the spec 2).....it was my last engine before I quit offroad....now I m thinking of getting back and upon checking the engine, everything are fine, only the compression is loose. So if I want to rebuilt the engine will the newer B2101 piston, liner & conrod assembly compatible with the Speed XZB? Or is there any other alternative choice that can be use? Thanks in advance for the info.
dameetz is offline
Old 07-14-2015, 02:25 PM
  #5155
Frank L's Avatar
The B2101 will not work unless all of the internals are B2101.
Bore and stroke are different.
Frank L is offline
Old 07-14-2015, 06:10 PM
  #5156
Is the crank different in the B2101 than the speed version II? Ive heard that the blue head ver2 and and the speed 2 have the same crank its just in the speed 2 the crank has been dlc treated.
Old 07-14-2015, 07:25 PM
  #5157
Frank L's Avatar
I'm not 100% but I would say that the blue head ver II and the spec II are very close. I have been told that the timing on the B2101 is very different.
Frank L is offline
Old 07-14-2015, 08:13 PM
  #5158
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
I'm in the exact same boat, but with a blue head spec 1 XZB. I was thinking of putting the spec 2 P/S/R (p/n: 22423110) or Ninja B02 P/S/R (p/n: JX13004), assuming these fit the spec 1?
ajj is offline
Old 07-14-2015, 08:21 PM
  #5159
Frank L's Avatar
I do know that the spec II p/s do not fit in the original xz speed.
Frank L is offline
Old 07-16-2015, 08:40 PM
  #5160
Retired09's Avatar
Anybody know the difference between the VZ rod Part #23755020 and the XZ spec II rod Part #22425000? Do these rods have different center to center distances?
Retired09 is offline
