Best NEW Engine out!
Old 07-09-2010 | 06:00 AM
  #196
Redvet79's Avatar
Default RB MODS
Should be shim & rod
Redvet79 is offline
Old 07-09-2010 | 06:05 AM
  #197
Jakub Kusiewicz's Avatar
Originally Posted by Jaz240
I have yet to try an engine that I totally hated, but out of the list below of engines I have used, the only one that was not worth the price was the V-spec. It was toast after 3 gallons and that was with new bearings and rod at the two gallon mark.
Hyper .21 8 port ( 8 plus gallons)
OS V Spec ( 3 gallons )
Novarossi +4 ( 6 gallons and still going strong )
Werks B5 ( 3 tanks, still in break in stages)
Jammin JPX .21 ( 7+ gallons ) ( new one not yet broken in )
Ofna JL ( 3 gallons and ripping , but this one is Clocked )
OS SPEED V SPEC ???? or "blue" V SPEC ????
Jakub Kusiewicz is offline
Old 07-09-2010 | 06:23 AM
  #198
Funking-Awesome's Avatar
I believe he was using a blue headed v spec.
Correct me if I'm wrong Jaz.
Funking-Awesome is offline
Old 07-09-2010 | 09:05 AM
  #199
Jaz240's Avatar
Yes it was the blue one. That to me is the V spec. I call the $500 version the speed like everyone else
Jaz240 is offline
Old 07-10-2010 | 03:20 AM
  #200
MAGPIE-121's Avatar
Originally Posted by motomatt
........the MG66 is manufactured by GO ENGINE. Mark at Massive Mods has been a GO dealer in Australia for a number of years. He has extensive experience modding GO engines. The new GO GX series engines are the 6th generation of engines from GO. The MG66 is of Mark's design.
If I followed the history(thread) correctly the MG66 = Massive/GO/6th generation/6 port.
It's spoken of VERY highly in this thread. It's over 700 pages long tho.
Look for posts around the mid to late '09 time period for the start of MG66.
If I recall correctly, Trey (the U.S. GO importer) sent an MG66 to Neil for testing.
http://www.rctech.net/forum/nitro-of...hread-728.html
+1 MG 66, smooth as silk with power to burn
MAGPIE-121 is offline
Old 07-10-2010 | 05:29 AM
  #201
What about OS Speed ?
Old 07-10-2010 | 06:46 AM
  #202
Stalkie's Avatar
+ me too for the MG66, so smooth and its there when you want it.
And as far as run time, easy 11 to 12 min'(and thats me tuning)
Life of the engine- A team driver has been running a test on the MG66,Simply... it has not had a bearing or Rod change from day one, and has just given up the ghost at 62 Ltrs, I think thats about 13.6 Gallons
Stalkie is offline
Old 07-10-2010 | 08:31 AM
  #203
bigmatt's Avatar
Me 3, MG-66 for sure!!!!!!!!!!!!!!!!!!!!
bigmatt is offline
Old 07-10-2010 | 08:47 AM
  #204
Unsober1's Avatar
Originally Posted by token
Yeah, I have 3 vspecs and 3 sets of P,S,C........But since they are gone, I would like to try something new. Plus OS is pissing me off, not introducing the new engine at NATS.
I haven't finished reading all the post here yet, but Token, If you showed up for Nats, you might have known that the New O.S. motor WAS at Nats. Sure it wasn't shown off, but it was there. It had a different head on it, but it was there. I saw it out there for atleast one qualifer
Unsober1 is offline
Old 07-10-2010 | 09:10 AM
  #205
Flanno's Avatar
Life of the engine- A team driver has been running a test on the MG66, Simply... it has not had a bearing or Rod change from day one, and has just given up the ghost at 62 Ltrs, I think thats about 13.6 Gallons
The bearings needed changing at 40 ltrs, but yes the rod lasted 62 ltrs. from brand new including run in
Flanno is offline
Old 07-10-2010 | 09:34 AM
  #206
and?
dreaux is offline
Old 07-10-2010 | 07:41 PM
  #207
+1 MG66
gsd112 is offline
Old 07-10-2010 | 08:21 PM
  #208
there was only a few mg66 engines made right? I can't find them anywhere.
dreaux is offline
Old 07-10-2010 | 08:32 PM
  #209
Weird question here and I no there's a simple answer, why do rods have copper bushings? I burnt up 2 engines because my rods had the bushings wear out and it frustrates me that I see it happens to alot of people. So why do that make that one part of the rod copper? If I had to guess it's cause it's softer and easier on the parts it rotates around but that's my guess not anything more to support it. Thanks
Matt Piva is offline
Old 07-10-2010 | 09:14 PM
  #210
My guess is to absorb some of the vibrations. Copper is softer than the alum they use in these engines. Plus, I would rather spend 30 bucks for a rod than 100 bucks for a crank.
DuckStang is offline
