The New Werks B6 .21 Buggy Racing Engine!
#1366
They are correct the 2013 is no longer legal for EFRA races. However for the US or non EFRA Sanctioned events it's all good
#1367
what does the plug look like that is "bad"? plugs can fail from being too rich, too lean, something foreign in the engine, also do you have a GOOD glow ignitor?!? I have done that at the track go to start my vehicle and bburrrraaa goes the starter box with nothing (odd my engines alyways pop right off) pull plug check it no light WTF weird? toss the plug put in a new new bbrraaaa again grab another ignitor and vrrooommm lol if you need a plug lemme know and I will send ya one out since Ron is out right now.
-Ryan
-Ryan
#1368
-Ryan
-Ryan
#1369
Some of the latest B6 engines I have gotten have come with the Werk's #6 plug..... This is an excellent glowplug, very heavy duty and very durable...However it does use a heavier coil element then most plugs and because of that I find it needs a little more juice to light..If your glow ignitor is weak it may not be adequate to light this plug.....I have now seen a few people throw away a perfectly good #6 simply because their glow ignitor was not strong enough for this plug...They ran the engine too rich and when trying to restart the ignitor couldn't get the plug hot enough to burn off the accumulated oil from the previous run.......So in the end the Werk's #6 is a killer glowplug, runs strong and seems to last forever, however it does take a little more juice to make it glow really hot !
#1371
2057-Smoothest linear powerband which will equal most mileage.
2058-Stronger bottom but keeps excellent top, good mileage as well.
2013-Lots and lots of bottom end.
Any you could probably get decent mileage with depending on how hard you are on the throttle, I run the pro class similar to you and I stick with the 2057 or 2058...
#1372
Reving up in the air
Just went thru 15 tanks and just noticed that on 2 of the bigger jumps the engine will rev up on its own while in the air. Clunk looks normal. Can't figure out what it could be.
#1373
that means the engine is "running" on which usually means you are lean somewhere or a large idle gap?
#1374
WERKS
My WERKS B6 powered beast!
Thanks Ron for all the help!
#1377
#1379
