The New Werks B6 .21 Buggy Racing Engine!
#166
thanks ! you are great ! every where we race everyone is impressed with the werks motors , power , run time , awesome sound , and unbeatable price ! now there are several racers running them and alot that are going to get one at the tracks we race . thanks again
#167
That's a strange one then because over the years that's the only way that I have seen the skirt break. In any case you have a couple of our engines and I appreciate that! Todays the 4th and I'm planning on having some fun so today the only thing I'm going to be operating is a BBQ grill lol! Just send me a pm tomorrow and I'll swap it out with a new one for free. You have a lot of choices when it comes to engines and I want to thank you again for choosing to use our products! Have an awesome 4th of July!
Regards,
Ron
Regards,
Ron
#168
#169
You will not find better customer service ANYWHERE
Ron is the man and the Werks engines are unbeatable in my opinion. The price is killer and they put out amazing power and runtimes. Really what else is there?
Have a great 4th Werks Crew!!
#170
Isn't there a new clutch coming out? Did I totally miss it or it hasn't happened yet?
#171
Happy 4th to everyone, firing up the grill now! Enjoy and again thank you to all of you that are using our products and have supported us! You guys allways thank us for supporting you but the reality of the matter is withou all of you guys none of this would be possible! So thank you again and happy 4th!
Regards,
Ron
#172
how does the B6 run with a ninja/2060 pipe. Curious to know because if i were to get one of these motors i would try and avoid buying a new pipe...
#173
This engines are made around the 2013 and 2057 pipes and some people like the 2035 also. This engines will run with any pipe that you use on them but you get the must out of them with the 2013 and 2057. Do a test with the 2060 and post how the performance was I wonder too how works.
#174
Just ordered my first ever new engine, a B6. I currently use OD97T's and sometimes 77T's. Are these compatible and good for the B6? Also I currently only run 20% fuel, is the shim setup etc. ok for this as it comes from the box? I usually run small (6mm) restrictors but have been playing with a 7mm and limiting the throw to 65-70%. It sounds like this is a longer needle carb so maybe I should go back to a smaller restrictor. Are my O.S. sized restrictors the same as the 2010 carb? Thanks for the help, I'm like a kid at christmas waiting to run my new engine!
#175
Regards,
Ron
Regards,
Ron
#176
http://www.amainhobbies.com/product_...Restrictor-6mm
http://www.amainhobbies.com/product_...estrictor-65mm
Also, a case of Werks fuel is on special at A Main Hobbies for $87.99! Get it while its hot! (or cold).
Update: I did try to put a 6mm OS Speed venturi in the 2010 Werks Carb a few minutes ago. It fits, but it doesn't feel like it seals very well. If you take a Werks venturi out of a 2010 carb, you will notice its a nice, tight fit. The OS feels like it could almost fall out. I think your best bet would be to order a smaller Werks restrictor.
Brad
#177
The odonnell 97T works with B6 engine quite well, as does the Werks #5 and 6 series of glow plugs. Ron will know more about shim setup. Werks has you covered if you need any extra restrictors!
#178
#179
