REDS Engines (Mario Rossi)
#1351
What pipe are people prefering on there buggy and on there truggy with the R5R engine? I have a 2112 with a short header that is ment for truggy?
And also do you prefer the new side needle carb or the older type?
Cheers Aaron
Cheers Aaron
#1352
thats pretty consistent.. well weather isnt great but sunday is supposed to be better.. so we ll see if a practice can be squeezed in.. and race on the 17th of may.. in the mean time fiddle and will have the car the best possible..
#1353
Hi , I have two reds motors one is a r7 and the other is a r5t . What OD or Os plugs are u guys running in your motors . I run vp 30% race fuel . I just got the motor broken in and I need new plugs , thanks
#1354
http://www.amain.com/rc-cars/search?cID=&s=odonnell+97t
#1355
Are od 97 better then OS p3 or p4
#1356
as i recall many have liked od because of the thickness and wind of the wire .. and it lights up all the way consistently.. but yeah ive used OS p3 and havent had much issue.. has been a goto for me.. and now i have a stash of 97's so as some may have looked amain is selling them cheap.. so grabbing a pack of 10 would do you for a while..
#1357
I'm having some difficulty tuning my r7. It seems no matter what I try the engine wants to run on after a long straightaway. any suggestions?
#1358
Your LSN i way to fahr in. This engine likes a tad fat bottom end. My engines are just in from flush.
And something else, Picco based engines must be tuned a bit at a time. 5 minutes on the needles when you are close is to much. ( like OS...) Once you get it tuned right, you will find them very very consistent in tune.
Use Picco 5TH glowplug or the nr 5 Reds plug. For me it is the absolute best plug for the enigne.
#1363
Phillypete, check the temp of the engine, compare with other racers for your location
#1364
There aren't too many Reds motors in my area to compare to and the guys with experience on Nova or OS motors have a real difficult time getting my Reds to run right.
My engine temps have been around 200-210. Power seems a little sluggish to start but once it gets going it's pretty quick. Hence why we've been working on the LSN. Fuel economy has sucked. I've been struggling to get 8.
I'm going to take it back to flush on both ends and work on leaning out the top more and leaving the bottom as rich as possible.
#1365
