Like Tree182Likes
REDS Engines (Mario Rossi)
Old 01-18-2015, 09:16 PM
  #1246
Originally Posted by DaRaceMasta
LOL to tell you the truth the reds quattro just ran out of stock so this was the only option.. shame but it ll do the job for now..
Thinking about this for my truggy or is it to much? What is a good starting point for this 4 shoe on a truggy?
ready rollers is offline
Old 01-20-2015, 04:45 PM
  #1247
the wrench's Avatar
whats the deal with the HCX carb? another fad or does it really make a difference in tuning? all i see is the hs needle is now where a mid range needle would be... anyone try it yet?
the wrench is offline
Old 01-20-2015, 11:28 PM
  #1248
am
There are more to it than that, there are a differnece in the carb body as well. I have not tested yet, but i have the carb ;-)
am is offline
Old 01-21-2015, 04:04 AM
  #1249
the wrench's Avatar
i figured its "different"... what i want to know is if it really changes the inherent flaws with all slide carbs, slide slop, low end needle deflecting and messing with tune, lsn needle wear where it enters its "seat", sealing of the slide,, bla bla bla, ...my personal theory is the carb is the issue with nitro not being reliable, and i wish any company would sit down and really redesign the theory of fuel delivery, i dont think the hsn location has ever been a problem, its always down to to lsn setting/idle gap that has plagued me with flame outs from time to time
im not here to flame, and i apologize to reds if my text comes off like that...i own a te2 and LOVE it, and it tunes just fine, but i couldnt help thinking "oh great, another gimmick"
Old 01-21-2015, 04:07 AM
  #1250
https://www.facebook.com/photo.php?f...2&l=edfa6ba9d4
finally its time to do some cherry poppin.. REDS time!
DaRaceMasta is offline
Old 01-22-2015, 03:52 PM
  #1251
Trader Rating: 96 (100%+)
hi I have a R7 that ran almost 10 gallons already ( still have little pinch ) and I want to ask did you guys will try to buy the parts to rebuild it or just go get a new one ? but if I rebuild it what parts did I need ??? my R7 from brand new to now I never open or change anything, just put nitro and run.
teddymp9 is offline
Old 01-22-2015, 03:57 PM
  #1252
just get the full rebuild kit.. piston , sleeve , conrod with pin.. it is a limited run as i recall of these engines so better stock up... shame.. i was going for this evoke but it just ran out of stock here locally so..
Old 01-23-2015, 08:10 AM
  #1253
am
At 10 gallons, you should also change your front and rear bearing, and that is another 70+ bucks. And your not shure how your crankpin is eiher.
I would assume a full rebuild would be 230-280 dollars. I would have bought a new one.
am is offline
Old 01-23-2015, 09:55 AM
  #1254
I live in the the U.S. there are two main companies here that pinch engines (the sleeve really) which restores the compression. I've sent 3 or 4 TE2's in to get pinched over time when they've worn out. They measure the parts inside the engine to see if they're with in Spec. Usually they need the pinch, bearings and con rod. They run like new after that. The crank is only good for one pinch, then its out of spec at the pin and not worth it pricewise to rebuild. RcRenew.com is one of them. Not sure if they do that where you are.
My ST-RR EVO is offline
Old 01-23-2015, 11:06 AM
  #1255
Yeah I check on the reds website if I get all the rebuilt parts it will cost more than $300, than I think I just run the engine until it die and than buy a new one. Thanks all that give me the recommendation.
teddymp9 is offline
Old 01-23-2015, 03:08 PM
  #1256
I am using the HCX Carb since a couple weeks now and was surprised by the changes actually. I can have a lower and more stable idle, I feel the engine does react quicker when accelerating, and it definitly has more top end. I haven't seen any change in consumption though. I am not regretting that I got one...
thommi is offline
Old 01-23-2015, 03:57 PM
  #1257
hmm ok thanks for the feedback
Old 01-23-2015, 03:59 PM
  #1258
https://www.facebook.com/photo.php?f...2&l=2913661509
nearly ready for tomorrows race.. will try run the REDS in today..
Old 01-25-2015, 05:36 AM
  #1259
https://www.facebook.com/photo.php?f...2&l=4150facc56
idled like a dream and so far but at least .. it has had just shy of 2tanks.. at 100c - 120c+ to bed in.. will peep inside and see how the engine looks after run in..
Old 01-25-2015, 11:44 PM
  #1260
moxford's Avatar
http://youtu.be/BDVaO15RTsc
my Team C T8, ready for the new season, R5R engine, with a Hipex pipe
moxford is offline
