Like Tree183Likes
REDS Engines (Mario Rossi)
Old 08-10-2014, 05:33 PM
  #1096
shanef's Avatar
Trader Rating: 38 (100%+)
Originally Posted by ehames005 View Post
What pipe would you recommend for a R5 in a truggy?
I use the 2099 with the short manifold.
shanef is offline
Old 08-11-2014, 02:10 AM
  #1097
malcnz's Avatar
Have the new v2 reds team edition that i got off another racer and wouldnt run on the weekend which is first time out and turns out the ARO he used has eaten away at the silicon in the crank and was fouling the glow plugs so it wouldnt idle etc.
Should i just clean out all the silicon from engine including from the crank and leave it unfilled or get it redone?
Thanks.
malcnz is offline
Old 08-11-2014, 06:42 AM
  #1098
am
It will run fine without the silicon on the crank :-)
am is offline
Old 08-11-2014, 06:51 AM
  #1099
Winner's Circle's Avatar
+1
Lee
Winner's Circle is offline
Old 08-11-2014, 08:00 AM
  #1100
Same thing happend to me... The engine runs with no problem BUT you lose bottom end power
segreda is offline
Old 08-11-2014, 09:41 AM
  #1101
modhobby's Avatar
Trader Rating: 25 (100%+)
Originally Posted by LightningStruck View Post
2113(2069)
Correct, the 2014/S might work well too, but the 2113/M or S is the first choice.
modhobby is offline
Old 08-11-2014, 09:42 AM
  #1102
modhobby's Avatar
Originally Posted by Winner's Circle View Post
+1
Lee
FYI for everyone. The 2099 was discontinued in favor of the 2104. We felt in testing the powerband and results were almost the same. I still think I have some 2099 in back stock if anyone wanted to snatch them up.
modhobby is offline
Old 08-14-2014, 01:01 AM
  #1103
Is the carburetor on the TE2 version 2 identical internally as the original Team Edition 2?
My ST-RR EVO is offline
Old 08-14-2014, 06:30 AM
  #1104
modhobby's Avatar
As far as I know there were no changes there.
modhobby is offline
Old 08-14-2014, 12:23 PM
  #1105
thanks bro
Old 08-20-2014, 06:01 PM
  #1106
madweazl's Avatar
I'm a Reds rookie but was interested in the R5R. What is the powerband like? Currently running a B6 and really like it but I'm always looking to try something else in the $300ish range.
madweazl is offline
Old 08-20-2014, 06:24 PM
  #1107
BigInJapan's Avatar
Trader Rating: 18 (100%+)
I run one in my NB48 and honestly, with one shim removed, running 25% it's basically too much motor for the buggy. I am now looking for ways to smooth the powerband.
BigInJapan is offline
Old 08-20-2014, 09:23 PM
  #1108
madweazl's Avatar
I was a huge fan of the GRP Tuned and Rossi in general. Is there no pipe/header option that provides a nice, linear powerband? I so miss the GRPs and the B6 has been about the closest thing I've been able to find since.
madweazl is offline
Old 08-20-2014, 09:41 PM
  #1109
BigInJapan's Avatar
The GRP tuned will definitely be more controllable in a light buggy such as Tekno. I'm already running an xtra short header and will be trying a 2104 'smooth' pipe as well as tuning the clutch, which I suspect will make the biggest difference. Keep in mind that this is with the extra compression of one .1 shim removed, I may need to re install it if I can't tame it enough. Won't change the engine out in a hurry though as it is very stable at idle and I am getting phenomenal runtimes out of it
Old 08-21-2014, 11:14 AM
  #1110
sykemike's Avatar
Default stubbron mixture screws
Hey dudes, has anybody have mixture screws move or back out on you? The reason i ask is my mixture screws (high and low) are very hard to turn out or in. Putting dings in the slot of the head of the mixture screws. Almost feel like i'm going to break the head off. Anyhow i back both high and low mixture screws out and put grease on the o rings and put them back in. Question is did i SCREW UP or what? Please chime in and let me know. Thanks in advance.
sykemike is offline
