Like Tree45Likes
REDS Engines (Mario Rossi)
Old 04-29-2018, 03:46 AM
  #2101
What pipe and header would you guys recommend for he WRX in buggy and truggy?
Whitey_Wangster is offline
Old 04-30-2018, 07:28 AM
  #2102
Or would the WRX be to much for buggy and truggy?
Old 05-01-2018, 03:43 PM
  #2103
I know what companies engine I won't be buying. They can't even answer a e-mail in US or Italy. I was going to buy four to....
Old 05-01-2018, 04:19 PM
  #2104
sancho's Avatar
Trader Rating: 1 (67%+)
I run the WS7 with the x-one 2104 smooth pipe in buggy and the WRX x-one2104 torque pipe in truggy. RC tech is kinda dead. Your best bet is to post on FB either on Reds racing or Reds racing USA
sancho is offline
Old 06-18-2018, 01:01 PM
  #2105
Default updside down flame outs
The past several race weekends my REDS WR7 has flamed out when upside down after some time waiting for marshalls. The clunk in the tank seems fine. It doesn't flame out like its fuel starved revving and then dying it just dies all the sudden. Starts right back up no issues. Happens way too often. Engine is tuned very well, idles forever, no lean bogs, no clue what this could be. TEKNO NB48.4. Please help thanks.
mtwinste is offline
Old 07-01-2018, 06:20 AM
  #2106
As you know alot of different issues can cause a flame out. I would fill the tank after she has been warmed up after a few laps and then bring her back in to the pits and turn her upside down and see if she flames on you. If she does and you've changed the plug/checked all the fuel lines/ checked o-ring on tank/ standard stuff as you would. I would run her again on track till warm then bring in and check temp/ have someone else check temp as well with separate temp gun.
I've seen flame outs upside down caused by Rich Low Needle but masked by high idle screw setting. Probley not your issue as you said you've had good tunes on it.
how many gallons do you have thru it ?
NITROJUICE is offline
Old 07-01-2018, 11:46 AM
  #2107
id say about two gallons.
mtwinste is offline
Old 07-03-2018, 04:45 AM
  #2108
hyperfuxx's Avatar
Trader Rating: 27 (97%+)
How often are people changing these bearings out? Seems like they need to be changed out more frequent then other engines.
hyperfuxx is offline
Old 07-26-2018, 12:58 AM
  #2109
Trader Rating: 124 (100%+)
Default Reds WR7 2.0
The info below is copied from Reds Racing USA. Sounds like they left everything else the same and changed the carb a little.
REDS Racing All-New WR7 Diamond 2.0 engine. The new engine is a 7 special porting extreme power engine based on WR7 Diamond edition. The engine comes with the same sleeve and piston, crankshaft, crankase, etc. as the first generation of WR7 in order to keep its power characteristics unchanged.
We decided to improve the previous version with:
- Improved idle stability and tuning options thanks to a new 3 needles setting carburetor.
- Improved mid to top range power curve and feeling thanks to a special low speed needle and mid range spray bar.
- improved cooling system specifically developed to widen the operating range so that the engine can work well in extremely hot conditions. Furthermore, the new cooling system has been created to guarantee a more consistent tuning in every track condition.
- DLC Coated Crankshaft
Could the carb be used on my WRX and WR5 to make them 2.0 as well?
8ight-t_sbs is offline
Old 07-26-2018, 06:40 AM
  #2110
It looks like a traditional 3 needle carb now. I'm guessing that's better than the horizontal hsn?
qstorm777 is offline
Old 07-26-2018, 02:06 PM
  #2111
It looks just like the carburetor on the picco v1.
Houmb is offline
Old 11-16-2018, 07:15 PM
  #2112
mtbkym01's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Arctic RC View Post
I have a few spare glowplugs (P5TH Picco) from my last engines. Are they any good in REDS engines? Same as T5C?
Iím also interested in this, to use in a WRX
mtbkym01 is offline
Old 02-28-2019, 07:43 PM
  #2113
Whatís the word on the WR5 Italia?!?!? Just picked one up. Is it just a WR5 with the new carb?
Canít wait to try it out.
Old 03-02-2019, 03:58 AM
  #2114
I just installed the WRX Corsa with the smooth pipe in my mp9.
Niz55 is offline
Old 03-02-2019, 06:18 AM
  #2115
I have a great interest in the Reds WR5 HE.
But I do not know if it's a good bet.
Pedro Jesus is offline
