Like Tree43Likes
REDS Engines (Mario Rossi)
Old 01-04-2018, 03:31 PM
  #2071
Kyosho Kid's Avatar
How did you see a picture of that??
Kyosho Kid is offline
Old 01-05-2018, 05:18 AM
  #2072
https://www.facebook.com/redsracing/...type=3&theater
Kyosho Kid likes this.
Pedro Jesus is offline
Old 01-09-2018, 03:39 PM
  #2073
R/C Tech Elite Member
Trader Rating: 15 (100%+)
Originally Posted by BigInJapan View Post
In my opinion the Corsa Lunga has it over the Spec3
According to TNS's dyno, a stock R5R makes over 3hp, and his modified one 3.3. According to same dyno, big blocks make from 3.3 to near on 4hp stock.
I believe the Reds dyno numbers...
Did you run the engine yet? if so, impressions?
mlax is offline
Old 01-09-2018, 04:07 PM
  #2074
BigInJapan's Avatar
Trader Rating: 16 (100%+)
Not me but a couple of vids from team manager. I'll update once I've run mine too.
https://m.facebook.com/story.php?sto...23289771231417
exheliguy likes this.
BigInJapan is offline
Old 01-10-2018, 02:31 PM
  #2075
Hello I am looking at buying a reds Vegas world motor what motor are they close to in design .and are the worth it thank you
AETRUGGYMAN is offline
Old 01-10-2018, 03:51 PM
  #2076
WR7
mlax is offline
Old 01-14-2018, 04:08 AM
  #2077
Default Manifold
hi i'm using a red7 rvo evoke with the 2104 exhaust pipe and manifold S. we run in a small astroturf circuit.
The problem we have is that the engine is too soft down due to the high traction surface. Does anyone know the Reds manifold measurements?
I have an exhaust pipe OS 2090. Did someone test the 2090 on reds engines?
manuelvigo is offline
Old 01-14-2018, 04:35 AM
  #2078
am
Gear 13/48?
What clutchsetup do you use?
I think OS2090 will just make it worse s the OS pipes is somehow a little restrictive as OS engies has alot of timing.
am is offline
Old 01-14-2018, 05:07 AM
  #2079
Originally Posted by am View Post
Gear 13/48?
I am using
Gear 13/46
Kyosho clutch aluminium
1,0 springs
this configuration with the motor os B2101 + 2090 worked very well
Old 01-15-2018, 05:04 AM
  #2080
am
chenge gearing to 13/48. That will help alot.
clutch is good. you could try one 1,1 spring and two 1,0.
am is offline
Old 01-15-2018, 04:40 PM
  #2081
Definitely try the 48t spur gear. A reds bottom end pipe should also help.
windellmc is offline
Old 01-15-2018, 10:37 PM
  #2082
ok, I'll install the 48t gear. Thank you very much for your comments
Old 01-16-2018, 10:45 PM
  #2083
Default R7 vs WR7
hello, someone knows why the reference (ES214802) of the wr7 sleeve is different from the r7 ref engine (ES214892).
I thought that the r7 and wr7 motors were the same. except for the dlc treatment.
Old 01-17-2018, 03:39 PM
  #2084
I donít think they are the same. I think wr7 may have more bottom end.
Old 01-18-2018, 01:12 PM
  #2085
jkas10's Avatar
Trader Rating: 123 (100%+)
The WR7 is ported slightly different to give it more bottom end power. It is noticeable. It has the DLC coating as mentioned, as well as a newer, lighter weight cooling head. I recommend the 2143 pipe with the WR7 to get the most power and still have incredible top end.
jkas10 is offline
