Like Tree47Likes
REDS Engines (Mario Rossi)
Old 12-11-2017, 10:48 PM
  #2041
shadaloo's Avatar
A little off topic I guess, but I just ordered a R5R combo w/2104 pipe and the 34mm quattro clutch. I was wondering do reds engines come with a glow plug? Amain and other sites seem to be out of the t5c plug. I plan to order spare plugs once Amain comes back in stock, but didn't want to overpay if the engine comes with a plug.
Is there anything recommended to get with the engine? I am trying to find a head heater in stock also... I have mostly ran electric the past 2 years but am trying to get back into nitro. My old os engine isn't working out so I ordered the reds combo after reading and watching some youtube videos about them. I am really excited to try the reds engine, but am looking for any extra advice!
shadaloo is offline
Old 12-11-2017, 11:31 PM
  #2042
R/C Tech Elite Member
Trader Rating: 15 (100%+)
I can't speak exactly for the R5R but the WR7 combo comes with a glow plug and every engine I've ever bought came with a plug.
mlax is offline
Old 12-12-2017, 12:11 AM
  #2043
Default Needle Settings WR7
Wanted to share my needle settings. These settings are after ~10 tanks so I'm sure the bottom and the top will lean out a little further:
Idle: 0.56mm in
Bottom: 0.28mm in
Top: 0.54mm in
mlax is offline
Old 12-12-2017, 06:45 AM
  #2044
jkas10's Avatar
Trader Rating: 123 (100%+)
Shadaloo,
Yes, the R5R will come with a glow plug. It may be a #4 which is a little bit hotter plug for break in. However, you can race with the #4 plug if you are not able to get a 5 in time. It looks like you run Tekno cars, based on your signature. You will need to run a tekno clutch bell with the tekno clutch bell retaining washer, or REDS offers a Tekno Durabell that will last nearly forever. I am assuming you have the basic nitro necessities covered, like the starter box, glow igniter, fuel and fuel bottle, etc. Yes, an engine heater of some kind is critical to proper starting of the engine and will extend the life of the engine by minimizing the metal-on-metal friction of a cold piston being forced into a cold sleeve. Even a heat gun will do. Best of luck! You will be pleased!
jkas10 is offline
Old 12-13-2017, 07:09 PM
  #2045
shadaloo's Avatar
Thanks for the replies i ordered the 34mm quattro clutch with it as well. Can't wait to get it! I think i have everything i need aside from extra plugs and a head heater... trying to find one but they are sold out it seems.
shadaloo is offline
Old 12-14-2017, 06:36 PM
  #2046
BigInJapan's Avatar
Trader Rating: 16 (100%+)
The r5r combo i ordered from amain came with the #3 plug, which is same as OS p3. Good for running in
BigInJapan is offline
Old 12-14-2017, 11:57 PM
  #2047
shadaloo's Avatar
Thanks, i can't wait to run this thing!!! 😬
Which plugs should i stock up on? and would byron's 30% be good?
shadaloo is offline
Old 12-15-2017, 08:40 PM
  #2048
jkas10's Avatar
Grab a few #5 plugs. I am partial to NitroPro Fuel, but Byrons is a very reputable brand.
REDS GLOW PLUG 5 Medium Hot TURBO (5C) Offroad
jkas10 is offline
Old 12-22-2017, 09:27 AM
  #2049
Reds/picco t5c plugs last a long time.
windellmc is offline
Old 12-29-2017, 05:11 PM
  #2050
BigInJapan's Avatar
Just got this bad boy. Cant wait to run it in...
mlax likes this.
Old 12-30-2017, 12:43 AM
  #2051
I'd be interested to hear if the Lunga is more buggy or truggy oriented
mlax is offline
Old 12-30-2017, 09:14 PM
  #2052
jkas10's Avatar
It is intended for truggy. Dyno testing shows that it is the most powerful REDS engine available. Ever.
jkas10 is offline
Old 12-30-2017, 11:19 PM
  #2053
So basically Reds version of the Spec III?
mlax is offline
Old 12-31-2017, 12:12 AM
  #2054
I would like to know how true those numbers are from the dyno. 3.5hp would be as much power or more than the big blocks.
Cardiak is online now
Old 12-31-2017, 12:52 AM
  #2055
BigInJapan's Avatar
In my opinion the Corsa Lunga has it over the Spec3
According to TNS's dyno, a stock R5R makes over 3hp, and his modified one 3.3. According to same dyno, big blocks make from 3.3 to near on 4hp stock.
I believe the Reds dyno numbers...
