REDS Engines (Mario Rossi)
#1981
I'm assuming you're asking for buggy. The R7E with a 2104/Short header combo is super smooth, but not lacking in power at all. Mileage is about 9-10 minutes on my home track.
#1984
Reds WC M3 .12
I can't get my carb loose to adjust the angle of it to fit my new Nitro Tc. I have the screw removed but it doesn't want to budge. Even tried heating it a bit with heat gun. Any advice?
#1986
Loosen the screw only a few turns, then tap on the back of whatever tool you're using to push the other half of the wedge outward. (With the tool still in the screw of course) Then you should be able to wiggle the carb back and forth a bit and remove it.
#1987
My Reds WR7 Diamond has turned out to be a real beast! Very happy with its performance
Just going to need another for my buggy now! Lol
https://youtu.be/i7wBi5va2Sk
#1988
I believe you just set the needles flush and tune from there. Just knowing that it will be way to rich, but should get you on the right path
#1989
Did some more test runs on the reds WR7 today. Ready to take it to the track now and get it dialed in for racing
https://youtu.be/bX0HnkLJOBM
#1991
No
#1992
#1994
At this point the hsn was a bit lean & the lsn a bit rich. On a super hot day in Texas, it doesn't take long to heat up lol
#1995
So tell me, what runtime are you guys getting with the WR7 engines ?
What clutch setup and pipes are you using as well ?
I've just recently done the break-in on my new WR7, so it's not up to race tune just yet.
I'm curious as to what the general ball park is on runtime with the new technology on this race mill...
I've also got the Gen 2 REDS clutch, set to H position.
Lastly, what is the temps of the engine at your race tune ?
