Like Tree46Likes
REDS Engines (Mario Rossi)
Old 01-16-2017, 07:42 PM
  #1936
revo61's Avatar
Trader Rating: 18 (95%+)
Has anyone used Avid ceramic engine bearings before? Are they any good?
revo61 is offline
Old 03-20-2017, 10:37 PM
  #1937
Exhaust question. In truggy, I'm running the R5T with the 2112 pipe and medium header. I'm looking for a little more top end. Should I go to a short header? If so, do I lose a lot of the bottom end?
Also thinking about going with a 2113 with a medium or short header. Any recommendations on which header to use in truggy with a 2113?
Will I be able to get at least 8 min runtime with 2113?
qstorm777 is offline
Old 03-21-2017, 07:22 AM
  #1938
RokleM's Avatar
Trader Rating: 33 (100%+)
On the R5T, the 2104 and short is the recommended setup.
RokleM is offline
Old 03-26-2017, 06:36 AM
  #1939
rregl0612's Avatar
Default plug and temp selection, or temp to plug selection.
Ran our first round of nitro yesterday, east coat winters. Found the t5c gave a very small window, and even when tuned well, still didn't sound correct (sounded flat) temps were in the mid 50's to mid 60's through the day with a cold front moving trough around my main.
I arrived with a thought I may have to drop, so before mains I switched the t5c for a ts4, retuned, and she was back to a 5 second high idle and a happy gurgled idle after settling with loads of top.
The morale if this story is to trust your gut! I hesitated and could have qualified way better. Still any day of nitro fumes is a good day
rregl0612 is offline
Old 03-26-2017, 09:09 PM
  #1940
vandalzzz's Avatar
Can anyone measure inner diameter and inner depth of Reds clutchbell from their modern clutch system? Can't find Reds clutch thread, so decided to ask here.
vandalzzz is offline
Old 04-03-2017, 05:19 AM
  #1941
New Reds engine with DLC crank.
REDS WR7 Diamond Edition in video -NeoBuggy.net ? Offroad RC Car News
kyosho28 is offline
Old 04-13-2017, 06:32 AM
  #1942
Originally Posted by kyosho28 View Post
What's the difference in performance between the wr7 diamond and the R7 evok 4.0? Is it the same engine with a dlc crank
shark2288 is offline
Old 04-14-2017, 03:34 PM
  #1943
erc55's Avatar
Default Quattro clutch bell
I know Novarossi clutch bell work with the Reds Quattro clutch. Does the Fioroni steel bell also work? What other clutch bells work? I saw a picture of Maifields car in Neo17 and his clutchbell doesnt look like Reds, anyone know which brand it is?
erc55 is offline
Old 04-15-2017, 09:57 AM
  #1944
Cant drive's Avatar
I've run the protek bell for Mugen and it fits and works fine. However the reds durabell is superior in every respect.
Cant drive is offline
Old 04-16-2017, 08:58 PM
  #1945
Sinn1612's Avatar
For an R7E (V3), between the 2104+S and 2143+S, what would be the best all-round pipe?
Sinn1612 is offline
Old 04-16-2017, 11:52 PM
  #1946
Iv got both pipes
I'm using the 2143 +s manifold with the R7 V3.
WavyEnzo is offline
Old 04-17-2017, 12:25 AM
  #1947
Sinn1612's Avatar
Originally Posted by WavyEnzo View Post
Iv got both pipes
Thanks for the reply. Why are you using the 2143 over the 2104?
Sinn1612 is offline
Old 04-17-2017, 04:26 AM
  #1948
For me the 2143 has overall power. From low-Mid-Top
2104
Has Mid to Top speed.
So really depends on your style of driving.
Are you using the reds racing clutch system.
WavyEnzo is offline
Old 04-17-2017, 06:31 AM
  #1949
Sinn1612's Avatar
2104
How do you find the mileage between the two? I would hazard a guess that the 2104 has slightly better mileage given the lesser torque.
I use the TLR clutch.
Sinn1612 is offline
Old 04-17-2017, 06:40 AM
  #1950
Tbh.. I haven't used the 2104 pipe yet..
But they say, you get better fuel mileage
When using the reds, 4shoe clutch system.
But I would say, the 2104 pipe, would give a lil better fuel mileage then the 2143. But as I said, just depends on your driving style.
WavyEnzo is offline
