REDS Engines (Mario Rossi)
#1501
EFRA 2112
HIGH TORQUE
EFRA 2112 exhaust guarantees great torque and good fuel economy. REDS 2112 is suitable for medium and long tracks. It is advisable to combine the pipe with S or M manifolds.
POWERBAND RPM
Low ●●●●●
Mid ●●●●
High ●●●
EFRA 2113
HIGH POWER AND TOP SPEED
EFRA 2113 exhaust guarantees great mid and top power and average fuel economy. REDS 2113 is suitable for short tracks. It is advisable to combine the pipe with S or M manifolds.
POWERBAND RPM
Low ●●●●
Mid ●●●●●
High ●●●●●
#1502
can someone from reds confirm which engine out of the r5r and r5team has the
most bottom end as i have heared diffrent opinions on this.
#1503
The manifold and pipe, plug, clutch, gearing, engine tune and tyres all have a part to play, even the air temperature, so expect different opinions.
#1505
I just bought the R5S for my truggy and was wondering what kind of run time I should hope to achieve?
#1506
The real answer is, tune your engine for the right temp/performance, then see what your runtimes are and if they're around what you're looking for.
#1507
Data from the Reds Racing page:
EFRA 2112
HIGH TORQUE
POWERBAND RPM
Low ●●●●●
Mid ●●●●
High ●●●
EFRA 2113
POWERBAND RPM
Low ●●●●
Mid ●●●●●
High ●●●●●
EFRA 2112
HIGH TORQUE
POWERBAND RPM
Low ●●●●●
Mid ●●●●
High ●●●
EFRA 2113
POWERBAND RPM
Low ●●●●
Mid ●●●●●
High ●●●●●
2113 HIGH POWER AND TOP SPEED for short tracks
this looks the wrong way round to me
is this a mistake?
#1509
I have a really dumb question on my engine. I just put in my new 5TH and was running it on the track and was running great, temp was around 190. So I went to lean on it and it created a bog. Somtimes it was half way in the straight and somtimes was at the end of it. I could not get the temp over 205. Any ideas?
#1510
Your to lean on top end. Reds engines does run alot cooler than moast other enignes due to the design of the head button.
#1511
#1513
Yes I put more fuel to it and it helped I just was new to reds motor and seen the temp really low. I was worried it being to low I guess. It ran best around the 195 range. Love the power with it. I also was fighting a storm rolling in and kept havin to play with the tune. Thanks for yalls input.
#1515
Lol I just seen that also. Still shows high temps I know mine won't run that.
