Crankshaft filling
Old 03-02-2010, 12:34 PM
gabor szilagyi's Avatar
Default Crankshaft filling
Does anybody knows what can I use for crankshaft filling?something should be between engine sealer and epoxy,but what exactly?
gabor szilagyi is offline
Old 03-02-2010, 02:02 PM
wfo
wfo's Avatar
I used red hi-temp rtv silicone . put a little amount in the crank and cut a piece of lexan the same width as the crank opening and round it at one end to smooth/ramp the silicone, mine came out really nice and is holding up......
wfo is offline
Old 03-02-2010, 03:03 PM
I been moding some of my motors for a while now and have had Great luck using good qauilty high temp red RTV silicone. Take ur time use somthing small an flat to help make it real Smooth. I also sand the inside of the crank with 1000 grit sandpaper and then clean with brake cleaner let dry and then apply. Speedrob
Speedyrob is offline
Old 03-02-2010, 03:38 PM
Default Thanks!
Thanks for the respond!
Old 03-02-2010, 03:51 PM
Integra's Avatar
Permatex has Nothing in their lineup that is Rated for Nitro Methanol.
1 product i use and Know works like a charm is Three Bond 1211.
Integra is offline
Old 03-02-2010, 03:58 PM
May not be rated for it but no problems using it. What is that three bond 1211 away down to try something different? Thanks speedyrob
Old 03-02-2010, 04:03 PM
Integra's Avatar
come again ?
Integra is offline
Old 03-02-2010, 04:05 PM
+1 for three bond 1211, that's what i use to fill all my crank, and to seal all my nitro engines.
Mathiew is offline
Old 03-02-2010, 04:08 PM
MontanaMaxx's Avatar
whats this 3 bond 1211 stuff never heard of it
MontanaMaxx is offline
What is three bond 1211??? Always down to try somthing different sorry for my fast typing. Where can i buy it at same place auto zone Etc. Thanks speedy
Old 03-02-2010, 05:41 PM
helivaguy's Avatar
Trader Rating: 42 (100%+)
http://www.reidrc.com/news.htm
helivaguy is offline
Old 03-02-2010, 06:08 PM
Trader Rating: 22 (100%+)
I dont see how that GE silicone in the link above can come close to the proper crank fill? The reason it is so expensive and hard to find is because it will resist expansion or contracting up to like 500 degrees. Also it is chemical resistant both synthetic and petrolium based fuel and oils. Thats what happend with the trinity engines that had so many crank plugs coming out and ruining engines or causing problems. The fill they used was not up to par. The chemicals in some fuel and after run oils compromised the integrity after a short time.
I myself used to run trinity engines and I bought a tube of the stuff from japan that is $80 a tube. because I had a few crank plugs come loose. The proper stuff will last past the life of the engine.
I would just hate to use cheap stuff and have a plug come out and jam between moving parts in an engine full throttle on a straight and ruin it. I mwan, I am sure a lot of stuff will work for a short time, but eventually maybe a gallon maybe 3 it will end up coming loose, at least from my experience......
heidmann1 is offline
Old 03-02-2010, 06:53 PM
Mr. Twister's Avatar
not hard to find at all actually, been using it for a few years now.
http://www1.mscdirect.com/CGI/GSDRVS...00000129140355
Mr. Twister is offline
Old 03-02-2010, 06:55 PM
Suspended
Trader Rating: 41 (100%+)
Holding up for how long?
Cadimman is offline
Old 03-02-2010, 07:47 PM
22Racer's Avatar
Trader Rating: 67 (100%+)
I use the Threebond 1211, works great, it is white.
Rex
22Racer is offline
