Like Tree9Likes
ALPHA OFF ROAD ENGINES
Old 02-25-2011, 09:05 PM
  #4336
t4ftracer's Avatar
Trader Rating: 73 (100%+)
Poinas has it pretty much.... 2mm from back of idle screw head to case, high speed flush, but low speed flush wil be excessively rich to the point that it may not even start.... I would start about 2 turns in from outer flush. Again as Poinas stated, with your idle screw properly set, you can relatively easily find the sweet spot for the low speed screw. If idle is high, richen the bottom. If low idle lean the bottom.
Hope this helps.
t4ftracer is offline
Old 02-27-2011, 05:12 PM
  #4337
Trader Rating: 37 (100%+)
Does anybody have a red head combo kit in stock? Thanks
chrisjohns is offline
Old 02-28-2011, 05:56 AM
  #4338
Originally Posted by DaveMozi View Post
Roughly what needle settings are you guys using on the new 7 port,
My 4 yr old decided to play mechanic So looking for a close starting point to fine tune from
3-3 1/2 turns out from fully in on the LSN, 1/2 turn from flush on the HSN
Should get you started easily.
Another bit of advice would be to pop down to your local store and buy some parcel tape to wrap around your 4 year old
Flipfly is offline
Old 02-28-2011, 05:04 PM
  #4339
king revo's Avatar
Trader Rating: 22 (96%+)
Default A872
i know i was told a couple weeks but has anyone have any feedback on it.. i heard nice bottom ( more than green but less than orange) and mid and top rips like a green. anyone?
king revo is offline
Old 02-28-2011, 07:56 PM
  #4340
jmaxey51's Avatar
i was told the grey head is just raw power... the red head to my understanding is kinda in between the green and orange.. red has good bottom to top.
jmaxey51 is offline
Old 02-28-2011, 10:46 PM
  #4341
Default re
if the grey has more than the green i want one
toofless is offline
Old 03-02-2011, 03:10 AM
  #4342
luke__'s Avatar
I have just started the break in on my green top. I did 4 tanks today
I idled one tank on the box starting and keeping it at 100c then let it cool to 35c. Then the next two tanks on the ground doing large figure 8s doing up to quarter throttle. The final tank today was doing large straights up to half throttle.
And I noticed that tonight the re seems to be a lot of oil coming from the front bearing.
Have i done something wrong?
luke__ is offline
Old 03-02-2011, 09:27 AM
  #4343
motomatt's Avatar
Probably not. It isn't real uncommon for a front bearing to weep/leak at breakin.
Very rich mixtures increase crankcase pressure and can cause the seal to leak. It's not uncommon for front seals to weep slightly even after break-in. Continue to monitor it's condition. If it continues to leak (not just weep) once it's broken in and tuned well, I'd recommend you replace it.
motomatt is offline
Old 03-02-2011, 10:50 AM
  #4344
MotoGod's Avatar
Trader Rating: 112 (100%+)
Does anyone know of any distributor that has Alpha Rods in stock with piston pins and clips? I have tried a few now...no dice.
MotoGod is offline
Old 03-02-2011, 11:25 AM
  #4345
motomatt's Avatar
Have you tried checking RW Mods? (22racer)
motomatt is offline
Old 03-02-2011, 11:45 AM
  #4346
apex-racing's Avatar
which motor?
apex-racing is offline
Old 03-02-2011, 12:12 PM
  #4347
Originally Posted by apex-racing View Post
which motor?
Should be the same on all ?
Poinas2 is offline
Old 03-02-2011, 01:06 PM
  #4348
MotoGod's Avatar
which motor?
Z852, but it doesn't matter...my parts list is universal to all the Alphas ;-)
I'll check with RW. I forgot he started to stock Alpha parts. I ordered the parts from Twisted-RC, but I haven't heard back from them and it's been 4 days now. So I need to ensure I get the parts before next Wed for PNB.
Thanks for the reminder about Rex!
MotoGod is offline
Old 03-02-2011, 01:57 PM
  #4349
check out the link it's in stock http://shop.rcproproducts.com/produc...&categoryId=17
Old 03-02-2011, 01:59 PM
  #4350
if you replacing a piston you should replace the sleeve also
