AB Mods Racing Engines
#152
Yea mud isnt the best track surface... Gets in EVERYTHING and REALLY weighs down the cars.... if not tuned for it the engine will lean out, blow out clutches etc. Hit me up if you have any problems figuring out the idle screw issues u were having with the speed.
#153
Adam did a few more tanks finish off break-in still not at its prime // setup 2060/P3 still running fat but holy crap very impressive awesome MILL temp average 175-185 motor sounds crisp
I have a extra OS speed crank do you recommend and should I swap into a P4. Im pretty much at sea level and Humidity averages 50%
#154
No harm in trying out the P4 and leaning it down some and see how you like it. Should be good for a slight power increase with the slightly cooler P4 plug.
#156
There still pretty new... Time will tell if they are mediocre engines, good engines or a GREAT engines!!
#158
OS engines have been around for a long time and have proven to be top notch mills with IMO the best carbs in the business. The new On Road XZR is no exception and IMHO is a score. It's a vast improvement from there old ZVR that's for sure. If properly maintained "rod/bearings changed as needed and tuned properly" should live a good long life! The one thing i would have really liked to see on the 21XZR would be DLC coating on the crankshaft....
The whole new XZ line from OS has been great so far and has yet to disappoint.
#159
#161
#162
Every engine Adam has done for us has been exemplary in performance.
A+ work, and supercool to deal with.
We are happy to have AB Mods as our RaceMugen.com modding source!
#164
Will do.
#165
Justleanit your engine went out to you today.
