New Ascendancy Racing Effortless Racing Clutch
#348
The clutch set up doesn't interfere with the motor mount so u can use whatever quick change mount you want for the Mugen!!!
#350
I have one in my d8 and it fits .The flywheel sits toward the front of the chassis cutout but it doesnt touch anything.The clutch bell i used is a thundertiger item as i had it in the spares box and it covers the shoes and the spur nicely. I had to shim the motor up about 0.7mm because i had a couple of flameouts after jumps. The flywheel touched a rock or something as it is very close to flush with the bottom of the chassis but that will be the same with any 34mm flyweel.
#352
Also, just want to remind everyone that we've got new lower prices on the clutch kits on our website, and new Carbon shoes available.
www.ascendancyrc.com
#353
I was reading thru threads and got a bit confused on the fitting of the clutch for the MBX6. Will the clutch bell of the MBX6 fit or would I need to get other clutch bells (MBX5) so that it can fit MBX6?
#354
I use mugen clutch bells with my ascendancy clutch on my mbx6t.... Works great....
#355
You mean the stock mugen bell that came from MBX6T?
#356
It depends on what brand engine you are running.
If you use a Ninja JX or aother type OS engine v-spec or speed, you will need the older MBX5 type clutchbell, or the Assendancy, Protek, Ofna.
For some reason the OS crankshafts are a few mm shorter then other brands off engines.
If you run a aother engine then the one i named above then try the MBX6T clutchbell first before buying a new one.
#357
I use stock clutch bell that came with my kit with an os speed and have no issues....
#358
Thanks. I'm currently using the alpha line of engines.
Just checked the parts listing of MBX6 with MBX6t to make sure they have the same part number and they do
Hopefully no modifications will be needed for the Alphas.
#359
hi i was just wondering where in australia can i get one of them
#360
Anybody have this happen to them? Been running this clutch for around 3-4 gallons and only had it apart a few times but today I had this. The bottom of the retaining plate broke off.
