Like Tree2Likes
RB Concept Engine Thread..
Old 01-13-2010 | 03:17 AM
  #901
JUD's Avatar
JUD
Originally Posted by aaron joy
Fellow RB K9 owners keep a eye on your bearings, I think they are really cheaply made. I ran into some problems last weekend with idle issues. I pulled my flywheel off to find the front rubber bearing seal was prying itself out. I dismantled the engine to also find the bearings felt gummed up and did not spin very freely at all, not gritty just not free. I ordered some Boca Bearing MX ceramic that I will be installing as soon as they arrive. My engine has about 4 gallons on it.
Thanks for the heads up Aaron. Is that pretty normal for most engines? Alot of people replace the bearings for better ones anyway? Thanks
JUD is offline
Old 01-13-2010 | 07:54 AM
  #902
Chris Peralta's Avatar
Originally Posted by 8&stuff
hows the rally9? i never seen till recently...
No Idea about the Rally9 sorry. I assume it is very similar to the B9 as the specs are basically identical.
Chris Peralta is offline
Old 01-13-2010 | 07:56 AM
  #903
Originally Posted by tc5 man
i have a question (i bought a used rb c5, from a racer that i know) and (it still needs to be, broken in its pretty tight.)im gone to (run 20% nitro there was no glow plug in, the cooling head.) so i have some (nova #5 plugs, will they fit the rb head?) is that the, right plug for that? percentage of nitro.
The Nova #5 plugs should work just fine in that engine with 20%. Do you know if it is a C5 or a C5BB?? The C5 is older and does not have quite the bottom end power of the C5BB or the C6 or B9. Do you have the box it came with or even the serial number can help determine.
Old 01-13-2010 | 08:11 AM
  #904
In general 4 gallons for a set of bearings is short for an RB. This is of course with the RB's that are manufactured by Novarossi. The K9 is built and assembled in Taiwan to offer a powerful engine at a great price. IMO in our hobby you generally get what you pay for, while the cheaper Taiwan engines can offer similar performance the quality just isn't quite there.
Old 01-13-2010 | 08:30 AM
  #905
8&stuff's Avatar
only thing i really noticed different was the price. looks like a great mill for about $200. at amain it says released over the summer. just seems funny i never notoced nor was there more feedback. almost seems like the $229 tag amain has is a typo
8&stuff is offline
Old 01-13-2010 | 10:02 AM
  #906
I looked a little closer at the Rally 9 and it looks like it comes with the carb that is on the lower end engines so it's not the really good carb that comes on the B9 or the WS9. The bore and stroke are the same between the B9 and the R9 but they do use different piston/sleeve and a different crank. Most likely the power curve is going to be different and may not be ideal for offroad racing.
Old 01-13-2010 | 10:07 AM
  #907
JUD's Avatar
JUD
Thanks!!
JUD is offline
Old 01-13-2010 | 10:30 AM
  #908
8&stuff's Avatar
may be an s5 with a 14mm crank and turbo plug. thanks for the look you took. still like to hear results with it..
8&stuff is offline
Old 01-13-2010 | 11:00 AM
  #909
Well I don't really think it's like the S5 either. It is a 5+2 booster port engine with the 3 MES exhaust ports so that is very similar to the B9/C6. The crank is also very similar to the B9/C6. I have a feeling the Rally 9's powerband is more similar to the Classico9 onroad engine than the B9/C6. Probably not a very good choice for an offroad buggy or truggy.
Old 01-13-2010 | 12:27 PM
  #910
8&stuff's Avatar
In your first post describing i had to toggle to amain and see if it were actually an onroad mill. All interestingly enouph as you say the r9 just aint gonna cut it.
I am looking for a budget italian mill preferably rb. At this point im struggling with possibly just sticking with a picco for truggy
8&stuff is offline
Old 01-13-2010 | 01:32 PM
  #911
For a budget RB I would say the either the Hobby9 or the K9. Is there a price range you want to stay under?
Old 01-13-2010 | 02:57 PM
  #912
8&stuff's Avatar
If the k9 was italion id be sold. not that good motors cant come out taiwan but i just dont see them pushing 10+ gallons. I run an s5 w/ceramics and turbo button now and still strong at 5+gallons although its time to be in the hunt for a good new rb. I guess im trying to stay as close to 200 as possible. Im looking at getting matching reliable investment mills for spring for bug and trug. The s5 is more my spare or buggy mill and then i run a jpx21 in my truggy at 4 gallons so i dont want to way underpower what im use to at the moment. Really leaning towards either this new picco evo or just another jpx and yeah very possibly just grabbing the k9. Iv seen a couple k9's in person and talked with there owners and they were both very pleased.
8&stuff is offline
Old 01-13-2010 | 04:29 PM
  #913
There is a link on here on the Rally 9 and this guy says it's got plenty of power for even his truggy. http://www.rctech.net/forum/nitro-of...rally-9-a.html
Old 01-13-2010 | 05:52 PM
  #914
tc5 man's Avatar
its a rb c5 engine thats what it said on the box,im gone to use it on the my truggy. nevermind i talked to him and he, said it was in a old box. its a s5
the rb box says c5 circuit racer but, i looked on the rb website and it said it had 3 ports? doesnt make sense. and the cooling head, is much bigger on the rb engine that i brought from ,a fellow racer . its a rb head.
the model number on the rb box says 1005-c
tc5 man is offline
Old 01-13-2010 | 07:04 PM
  #915
8&stuff's Avatar
might have to dig one
8&stuff is offline
