Like Tree2Likes
RB Concept Engine Thread..
Old 08-29-2014, 02:04 PM
  #3511
Originally Posted by BillyT.
V19 was all Nova. Even the RB guy at Amain didn't know the 19 had a different rod.
So which crank does it have then, is it the Nova Bonito crank?
exploded view says it's a 14.5mm
Eivind E is offline
Old 09-05-2014, 08:21 AM
  #3512
BillyT.'s Avatar
Dunno for sure. All I know is that the rod has a nova logo on it and the pin is 4.9. My 15 and old 11 both have RB logos on the rod and 5 mil pins.
here is a short vid of buggy with V15. It's a tooth lower on CB than normal (16 instead of 17).
+ YouTube Video
BillyT. is offline
Old 09-05-2014, 08:27 AM
  #3513
BillyT.'s Avatar
Also, on this 15, a problem I have never had before, if I run it completely out of fuel, the carb heat soaks and vapor locks. If you guys don't know what that is, it's when the carb slide becomes so hot that the fuel vaporizes as soon as it touches it and you get a no start condition. My old Losi engines did this, but they had all aluminum carbs. Engine temp is 235-245, nothing else out of the ordinary...
I guess the same thing could happen if I shut it down then tried to start it after about 15 seconds.... I don't think running it out of fuel really is the cause. I just don't remember ever having the problem before, struggling to restart after a flame out for whatever reason.
BillyT. is offline
Old 09-05-2014, 09:26 AM
  #3514
A tooth down in buggy? Doesn't sound promising for truggy(the V15 that is..)
Herrsavage is offline
Old 09-05-2014, 09:32 AM
  #3515
rceefreak's Avatar
Trader Rating: 154 (100%+)
So whats the verdict on the super long stroke bxr
rceefreak is offline
Old 09-05-2014, 09:34 AM
  #3516
BillyT.'s Avatar
It runs with a P5 like this down that straight. Would pull with the 17. Takes the whole length of the straight for a Picco 5tx team to get around it, on that same straight, with the 16.
I'm not sure it's any faster than the 19, but the 19 feels fine in the truck to me.
V20 with pipe is 255 at Amain... thinking about it... Also thinking about going Bullet... But these engines have a ton of life left in them.
BillyT. is offline
Old 09-05-2014, 11:23 AM
  #3517
rceefreak's Avatar
super long stroke bxr 5 with booster or bypass port info please
Old 09-07-2014, 07:15 PM
  #3518
mrbusta's Avatar
Trader Rating: 20 (100%+)
hey guys im after some advise i have a RB BX-R what glow plugs should i be running.
i have od 97t,77t, os p4 ,nova c6 thanks in advance
mrbusta is offline
Old 09-07-2014, 08:54 PM
  #3519
hambone's Avatar
Neal from Clockwork says it's their strongest .21 for truggy. That's modified however. I'm sure it's stout in stock form. Check out the clockwork thread and search for RB truggy video.
hambone is offline
Old 09-07-2014, 09:19 PM
  #3520
croracer's Avatar
I have really good luck with the werks #6.
croracer is offline
Old 09-09-2014, 02:18 PM
  #3521
markmad777's Avatar
Ive had our local driver try all of the new range BXR engines in STD form and we run and I supply the SLS3 without ceramic as RB supply the engine or I install before shipping as an option. The SLS5 and di5 didn't give an improved runtime and the low end was not as good as the SLS 3.All engines were run and tested using 2097 pipe with med header.Hope this helps LS5 gives very good results as well .
markmad777 is offline
Old 09-10-2014, 01:58 PM
  #3522
Pulse_'s Avatar
Hi,
just bought two used BXR (1 gallon) from team RB with a friend. One is a SLS3 and the other a SLS DI5
What would be the differences on a track?
thanks!
Pulse_ is offline
Old 09-10-2014, 06:55 PM
  #3523
Default Fire 11
Hi, I have a fire 11 but it was damaged when putting in new rod so now I need to put a new piston and sleeve (the rest is ok). I can't seem to find a matching piston/sleeve combo. Does anyone know where I can get one and also if I can't find the exact match, what else could I use?
Thanks.
bopracer is offline
Old 09-11-2014, 11:26 AM
  #3524
markmad777's Avatar
Originally Posted by Pulse_
Hi,
thanks!
The obvious thing is to say try both but run them on the 2097 with med header not the long one as supplied in the combo's.
We run the SLS3 with probably med distance tracks (40-45 sec) and milage is critical and the 3 gives better milage and more low down punch.Only thing is the 3 runs without ceramic as STD.
It will be good to hear which you prefer.
Old 09-14-2014, 02:37 AM
  #3525
RB Rocket to replace the Blast line...
http://www.redrc.net/2014/09/rb-rock...ne/#more-86084
So is that basically a Blast V20/Rally, or closer to a BXR?
