O.S Engines thread
#2836
#2838
Is there any manufacturer like Ultimate Racing MXS that is using the B2101 as a base? Kind of like the FP02 is based on the OS XR-B Spec 2.
#2840
I´m looking for a parts list for the AD3 engine like bearings etc. Searched but not found. Anyone got a link?
#2841
https://www.os-engines.co.jp/english...nual/1CJ00.pdf
#2842
Dear OS
please include a collet with your engines. It is 50 cents for you, but I just paid 10$ (inc delivery) because you are the only brad that does not include a collet with the engine. That is cheap.
cheers
cheers
#2843
#2844
Picco does, as well as a dust covers for the are and exhaust intakes.
Devil is in these little details.
#2845
ok
#2847
Collet taper angles aren't standardized, but most flywheels use the same taper angle because there's simply no reason RC companies to bother with a different flywheel taper (except for special fitments), when they can all just buy premade collets by the truckload for a fraction of a cent apiece from whatever Chinese factory has decided to specialize in making RC flywheel collets. So while collets for different flywheels may not be intentionally interchangeable, most of them are interchangeable anyway.
#2848
#2849
Anyone know if the head button from the spec 1 will work on the spec 2? I just got a rebuild kit for my spec 2 and noticed the button and piston head looks sand blasted compared to my other engines where they look smooth and have a tiny bit of carbon. Guessing it sucked dirt. But I have the previous xz-b spec 1 (first os speed of the new gen) I could use the button but I don’t know if it is the same. Anyone know? I could take pictures.
#2850
It should fit, but the part numbers are different
英12186 (os-engines.co.jp)
OSS21XZBsp2 (os-engines.co.jp)
