Like Tree132Likes
O.S Engines thread
Old 10-28-2020, 09:34 AM
  #2686
rc pete's Avatar
Originally Posted by Loua28
Hi Pete, thanks for the info. I didn't know about the ports that can cause issues. Just to make sure, why would the rod not work on the B2103. The part number is the same. The part number for the build up kit is 22423110. It is the Tessmann 110% parts.
Oh, you have the Tessmann 110% XZ-B kit. Yes, in that case the rod will fit both the B2103 and the B21 Ty2.
The XZ-B has multiple versions. The original Speed and Speed Spec 2 had longer rods, non-speed Version 2, the Speed Spec 3 and the Ty 110% has the shorter rod, same as all of the other recent engines.
rc pete is offline
Old 10-28-2020, 09:58 PM
  #2687
Wonder if os coming out with some new tessman model engines wjth updated carb balls and heads etc. they discontinued the ty 110% spec 2 and b21 ty2 engine last week. Or another thought will he switch to Fx engine?
Galatians2 20 likes this.
jersey is offline
Old 10-28-2020, 10:05 PM
  #2688
Another question, should I use the B2103 crank & head button on my rebuild or use the B2101 TY crank instead? What will the difference be if I'm able to use the B2101 TY crank in the B2103 casing?
Loua28 is offline
Old 10-28-2020, 10:11 PM
  #2689
Jersey, I'm getting my popcorn ready to see what happens...
Loua28 is offline
Old 10-29-2020, 09:17 AM
  #2690
rc pete's Avatar
In the B2103 definitely use the B2103 crank. That crank will achieve the required 16.8mm stoke. The Ty2 crank will only provide a 16.4mm stroke, which will not match up with rest of the engine.
Rick Vessell likes this.
rc pete is offline
Old 11-05-2020, 09:00 AM
  #2691
What os based motor best compares to the spec 3 motor ? I have been waiting hoping they would release a new model but haven’t seen anything on the horizon.
Ofna2005 is offline
Old 11-05-2020, 09:39 AM
  #2692
I don't think they have anything out there that is the spec 3(could be wrong). The closest thing I think would be the new Blok buggy motor, spec 2 internals with spec 3 case.
SkippyMatt is offline
Old 11-06-2020, 02:24 PM
  #2693
They did away w/the Spec III b/c it didn't fill a need - it didn't have the grunt of the Spec II/Tessmann 110% engine, nor did it have the linearity and good mileage of the 2101 or new 2103. The newest OS engines are the 2103 type R and type S, and the Ronda Drake AD2.
stephen_bess is offline
Old 11-09-2020, 07:07 AM
  #2694
Where can I get spec3 case from ? Mines leak right around carb area the warmer the motor gets the more the rpms go up . I tried sealing it, that was a temporary fix .
Ofna2005 is offline
Old 11-14-2020, 11:17 AM
  #2695
Try eBay. If not there, Tower Hobbies but it'll be full retail.
Old 11-14-2020, 02:47 PM
  #2696
maybe you you need new gaskets. Get a new insulator piece for the carb throat and a new oring and that might do it.
if that don’t work I heard the tekno BM case is a spec 3 case. I’m not 100 percent but was told that from a couple people.
https://www.teknorc.com/shop/tkr1724-crankcase-21bm/
but yea they discontinued the os spec 3 so os says sometimes they only manufacture parts till a year after it gets discontinued sometimes. Last time I looked for a spec 3 case couldn’t find them so tekno case MAy be the only route. I’d try the insulator and gasket first.
jersey is offline
Old 11-16-2020, 10:26 AM
  #2697
Samurai S03 and R03 are specs III based! B2103 case and oring head button.
inlinesick is offline
Old 11-24-2020, 08:41 AM
  #2698
Hi everybody , I would like to know what do you use to glue thermo insulator on 21J carb??? Or if you don't glue it??
maximax is offline
Old 11-25-2020, 03:20 PM
  #2699
The lrp zz21 long stroke David angaro is a spec 2 if this helps
Bigv is offline
Old 11-29-2020, 12:27 PM
  #2700
I've used a dab of CA glue just to secure it. The pinch bolt secures the entire assembly.
