Like Tree130Likes
O.S Engines thread
Old 06-18-2020, 08:48 AM
  #2641
Originally Posted by RCDaddy2105 View Post
I just made the switch to Bones Brew from Byronís.
Good fuel at a good price, good people running it too. Pretty cool that they offer a spout that fits their bottles too. No need to suck it out of a gallon jug, just thread it onto the bottle directly.
Locally we used to use vp but guys switched to byrons after going through a lot of rear bearings on vp. Now everyone is switching to bones due to cost (byrons got really expensive the last couple years) and people are having good luck with it.
windellmc is offline
Old 06-19-2020, 07:51 AM
  #2642
Just put 1% castor oil in the fuel and all fuel is ok. Can be bought ar a pharmacy as resin oil/laxative😂
MP10rocks is offline
Old 06-19-2020, 08:35 AM
  #2643
arydstedt's Avatar
I have a 2101 with about 5.5 gallons on it. Its my backup motor now. It was running great but all of a sudden started to have an unstable idle. Ive tried tuning it endlessly and even had some very experienced racers play with it and it would not stay lit. Ive heard it could be an air leak, or possibly bad bearings. I replaced both bearings and sealed the black plate, but its still doing the same thing. The piston looks great, no scratches, which I have experience with on other engines. Any suggestions thoughts? It still has compression and runs great, just can't stop for fuel or crash....
arydstedt is offline
Old 06-20-2020, 04:44 AM
  #2644
Try and spray brakecleaner on you front bearing while running on idle. If engine stops at onve bad front bearing. Unstable isle and lack of powwr down low is the first two signs of an engine reaching its lifespan. Check front besring forst
Old 06-20-2020, 10:57 PM
  #2645
HaulinBass's Avatar
Trader Rating: 16 (100%+)
Ran the bullet 222(b2102) with a carb and head from the tekno .21P, amr backplate and hipex 2135 evo2 with nova 41021 header. I really like this setups
HaulinBass is offline
Old 06-22-2020, 07:18 AM
  #2646
Rick Vessell's Avatar
Check the carb slide boot and o-ring at the base where it goes in the crankcase. There's an o-ring on the idle screw also. And make sure venturi is fully seated. Lots of guys pull the filter off to clean in and don't realize they've lifted the venturi.
Rick Vessell is offline
Old 06-26-2020, 12:46 AM
  #2647
Default Hi there
I habe the lrp zz21 square stroke engine and I can't find piston and sleeve I think it a b21 modify can anyone tell me about this and I've only ran it once I get it used and I love the motor in buggy thanks again guys
Bigv is offline
Old 06-29-2020, 11:55 AM
  #2648
What brand are we using in order to replace bearing? ProTek, TKO, OS, BocaBearing, AvidRC, ACER?
sebtarta is offline
Old 07-02-2020, 12:51 AM
  #2649
they will all work as long as they are correct size. Iím sure youíll hear a lot opinions cause Iíve heard people using all of them.
jersey is offline
Old 07-02-2020, 02:53 AM
  #2650
Hey gents, I just picked up a few VZB V-Specs in a purchase. They are used, but still in pretty good condition. Iím sure they would need some work to get going. I know these are very out of date engines, almost vintage! Lol What would you guys do with them? Invest some money in them to fix up and sell, try to sell used, or fix up and keep for practice engines? I have plenty of other engines that I race with, so donít really need them. Just looking for opinions/ideas?
xlrsd is offline
Old 07-06-2020, 07:43 PM
  #2651
Default Hi there
Hey bro other than fuel consumption engines have not changed much in the last 20 years I'm sure they can still compete today
Bigv is offline
Old 07-14-2020, 01:40 PM
  #2652
Default drill guide for OS FT-240
I am looking for a drill guide to drill out my prop so that it matches the washer on my engine. Any suggestions
jer2913 is offline
Old 07-15-2020, 10:22 AM
  #2653
I would suggest rcgroups.com. RCTech is primarily cars and surface use.
Old 08-01-2020, 10:41 AM
  #2654
Default OS SPEED B2101 Gold Edition
Hi everyone. Does anyone have or knows where to find online the manual for that specific engine?
Marios Chr is offline
Old 08-01-2020, 10:55 AM
  #2655
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Thats very vague... which motor? Usually on the OS Engines page there are many to include discontinued.
https://www.os-engines.co.jp/english...stop_list.htm#
1/8 IC Fan is offline
