Like Tree30Likes
O.S Engines thread
Old 11-27-2018, 11:43 PM
  #2491
am
Have you tried changing out your fueltank? Could me a hairline crack in fuelpickup or the interal line if you have a clunk.
am is offline
Old 11-28-2018, 02:36 AM
  #2492
Originally Posted by Hotspur View Post
I am having some issue with my 110% 21 xz-b spec 2. Will not hold a consistent tune. and once it gets low on fuel it cuts out. pulled carb apart everything clean. replaced front bearing, tank, fuel line, and plug. same tuning issue. The rear bearing is noisy going to replace that next. I used drakes settings as a base.... still have a tuning issue. 7mm insert and 25% byrons. any help would be appreciated thanks
Change rear bearing and see if that solves it if not.
replace fuel line, fuel tank. Maybe lid isnít tight.
Hows the compression on it? If not much compression engine might not hold a idle. Take the needles out of the carb maybe you have some blockage in carb. Flush carb out. Take engine apart check all the seals gaskets shims replace if needed. Maybe you have air leak. Check pipe gaskets and springs.
How skilled are you at tuning? Maybe have a local that knows os take a look if your not the best tuner.
jersey is offline
Old 11-29-2018, 11:01 PM
  #2493
foampervert's Avatar
Default Trolling for some opinions
Hiya folks,
​​​​I have access to some nib os .19 speeds for a decent price. I'm wondering if these engines are still competitive in this age of mega power longnstrokes, or should I just ignore them and go for something current?
Thank you for any opinions
Alexander
foampervert is offline
Old 11-30-2018, 06:32 AM
  #2494
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 84 (100%+)
Originally Posted by foampervert View Post
Hiya folks,
Alexander
The OS .19 Speed did really well, but given now the low cost of the current motors, I would save your money and get a .21 Speed instead. Given that your biggest headache is going to be finding PSR Sets! I used to get mine from Tower Hobbies, and now they are out.
Plus with a current .21 spares will be more plentiful.
Pedro Jesus likes this.
1/8 IC Fan is offline
Old 12-01-2018, 06:33 PM
  #2495
Replace the rear bearing before you go any farther. It will make a big difference on how it tunes and holds an idle...I used J&T ceramics in my drake motor and what a difference. I can fire it and walk away and it’s still at a low idle
Thanks for all the help. Changed rear bearing and its running great
Hotspur is offline
Old 01-01-2019, 01:04 PM
  #2496
New OS Speed B2103 Type S & Type R engines has been announced:
See neobuggy website. I am not still not allowed to post any links here.
BenPetz is offline
Old 01-01-2019, 09:56 PM
  #2497
O.S. Speed B2103 Type S & Type R nitro engines -NeoBuggy.net ? Offroad RC Car News
Anunnaki and BenPetz like this.
jersey is offline
Old 01-02-2019, 07:39 AM
  #2498
Expensive
Pedro Jesus is offline
Old 02-04-2019, 09:44 PM
  #2499
Super Moderator
1/8 IC Fan's Avatar
New case, new Carb, Love all the small details on the new motor!! Funny they went with a LP vertical finned "old school" Cooling Head.
BenPetz likes this.
Old 02-14-2019, 12:33 PM
  #2500
PinoyCali's Avatar
Hello Guys ,
What is the good aftermarket bearing for 21xz-b spec3?
PinoyCali is offline
Old 02-14-2019, 06:57 PM
  #2501
bypass911's Avatar
Trader Rating: 14 (100%+)
Originally Posted by PinoyCali View Post
Hello Guys ,
tko, j&t , or avid. Tried them all personally. Right now avid ceramic is in my spec 3.
Runs great cant tell any difference.
bypass911 is offline
Old 02-15-2019, 11:16 AM
  #2502
PinoyCali's Avatar
Cool ... Thanks
Old 03-18-2019, 01:21 PM
  #2503
HaulinBass's Avatar
would the 2050 be alright on a spec II in truck?
HaulinBass is offline
Old 03-18-2019, 02:39 PM
  #2504
kgombe's Avatar
tried it on the original XZB, and didnít like it. Saw a photo many years ago with it on tessmanís truck though, but to be honest itís hard to tell what engine he was running, it could of been the 2101, which he runs in truck as well.
i saw a side view so couldnít tell what engine.
kgombe is offline
Old 03-18-2019, 02:47 PM
  #2505
Super Moderator
1/8 IC Fan's Avatar
I ran the Spec II in my MBX7TR with the 2090SC (OSM72106192) pipe. No issues with lack of power and had good fuel mileage too.
