breaking in issues lrp zr32
Old 02-16-2016, 11:40 AM
Default breaking in issues lrp zr32
started breaking in process using engine heater checked gap on slide to make sure it wasn't to wide, engine took a while to start when it did it just screamed turn trim down a bit rpm did drop slightly then just cut out it repeated to do this on the 3 times i started it, and also wouldn't run without the glow start would i be right thinking that their could be a air leak issue or lsn/hsn settings arn't right from the factory and need to be readjusted any help much appreciated .
Madruss is offline
Old 02-16-2016, 02:52 PM
Suspended
Trader Rating: 61 (100%+)
air leak.
Socket is offline
