Mugen JX21
#151
Hi,
The introductory price will be $54.99.
The stock JX-21 head button (part # JX02001) retails for $54.99 and typically sells for $46 on most online shops. With the EB JX-21 head button you will also get a shim kit. When you guys see the dyno graph the performance difference is amazing! You're basically getting a modified engine without touching the engine internals.
If anyone has a brand new JX-21 B01 or B01A and wants to trade in the "new, unused" stock head button, I will also offer a buy back program. I will not take used head buttons though, so sorry. Ed will not modify used head buttons.
These head buttons are brand new Mugen JX-21 (part # JX02001) head buttons purchased from Mugen USA and then sent to EB Mods for modification. The head buttons are milled down on a CNC machine. Ed modifies the squish band for optimal performance. You do not have to re-break in the engine when installing the new head button. as with any other engine change, I would recommend richening up both the LSN and HSN then re-tune for performance.
Best regards,
Best regards,
#155
#156
Has the stock VSpec been put on the dyno with this new button?
#157
#158
So its the same button as the EB VSpec button? If so, I have one of those
#159
#160
Shimming was going to be my next question...so its shimmed like the EB Spec, with one thin copper shim.
I still think that a dyno pull with the EB button/stock VSpec and Speed could be benificial...if it shows enough of a power gain, then those buttons will sell like hot cakes
#161
Ps. Ed has so much data, I'm sure the button results from those engines are at his finger tip.
#162
luckily for me, my button is NIP And I havent looked in a while, but think there is a shim in there. See, I got a deal on all the EB Spec parts a while back, but have never put the engine together...so Ive got a stock Spec and a Speed plus all the guts to build a EB Spec...I like OS
Thanks for the info on the shims...I didnt realize there were three different copper shims
#164
Are you sure you got ALL the EB guts? Some mods EASILY go unnoticed.
