Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
low speed needle fuel line pinch test >
Like Tree5Likes
  • 2 Post By J.Whiting
  • 1 Post By petersen114
  • 2 Post By nitro coffee
Old 12-10-2023, 02:09 AM
sn47som1's Avatar
Default low speed needle fuel line pinch test
where are you guys pinching your fuel line for the pinch test? cant remember if it was right at the carb inlet or not.
sn47som1 is offline
Old 12-10-2023, 02:16 AM
briefer's Avatar
Omg, that is something from the past. I do not know anyone that still tunes his engine that way.
briefer is offline
Old 12-10-2023, 03:02 AM
sn47som1's Avatar
silly person, that doesnt mean nobody does it. you dont know enough people in nitro it looks like.
sn47som1 is offline
Old 12-10-2023, 04:23 AM
Roelof's Avatar
If you get your tuning right there is no need to do a pinch test. I never needed to use it....
Roelof is offline
Old 12-10-2023, 06:43 AM
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
right at the inlet fitting by the carb.
petersen114 and sn47som1 like this.
J.Whiting is offline
Old 12-10-2023, 07:36 AM
petersen114's Avatar
This^^^
sn47som1 likes this.
petersen114 is offline
Old 12-10-2023, 10:27 PM
sn47som1's Avatar
thanks to the ones that helped. so i was right, thanks for confirming. I think i always had mixed results doing it right at the inlet. it always wanted to be lean pinching at the inlet. I never thought it was a good test because of that. makes sense as its so close to the mixture/air intake
sn47som1 is offline
Old 12-10-2023, 10:38 PM
LosiPRRACER's Avatar
Pinch testing used to be used as a 'ball park' not as a check, So no point in doing if your tune is right.
LosiPRRACER is offline
Old 12-15-2023, 06:33 AM
its only used for a reference.
racing_jason and Troubles Dad like this.
nitro coffee is offline
