Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Truggy pipe and header favorites please >
Like Tree16Likes
Old 08-04-2023, 06:42 AM
Talking Truggy pipe and header favorites please
Im looking for power more than runtime. Either OS or Nova based engines I run.
I don't care about exhaust brand, just list anything you have loved for truggy.
nitro coffee is offline
Old 08-04-2023, 06:55 AM
Roelof's Avatar
There is no specific truggy header/pipe all is engine related.
Roelof is offline
Old 08-04-2023, 09:14 AM
petersen114's Avatar
It usually depends on the track. The only thing I run is Truggy. For my Ultimate M5S (OS based) I have 2 pipe/ header combos that I use. Mainly a 2141 and the header that comes w/ the pipe or I'll use a Protek 2090 w/ a 75mm header both on medium size tracks. for smaller tracks I use a Ultimate MSX w/ the 2141 pipe. When I was using Novarossi engine I used a 9901 and either a 41021 or a 41031 header depending on the track.
kgombe, sn47som1 and nitro coffee like this.
petersen114 is offline
Old 08-11-2023, 09:34 PM
All engines respond differently to different pipes but the ol’ 41032/9886 seems to be a ripper on everything. The 41032 Medium and long are awesome too . The Ielasi gtr is incredible on a few engines I have tested. 41031 w the 9886 or Asm 2171 is a good one . I recently ran the Max Power 2164 with their “long” manifold that comes with the pipeset on a Roma and it was shockingly good . Immediate trigger response and power and revs galore , funny is I ran that on a gt engine and it made the bottom end and even mid quite soft with a massive hit up top that made my buggy carry the front wheels for 20 feet at 35mph lol . Snatch up the 2164 /Max Long GT you will love it
nitro coffee likes this.
NitroPhene is offline
Old 09-27-2023, 12:33 PM
how are the ielasi pipes compared to an OS 2090? Im looking to get a 2090 hearing a lot of good things. I want to run it on a long header. Im looking for different header choices. I have the 41032 so don't really need the same header (gtr ielasi). I have a 41032 but dont know if its medium or long. The dont label it- just says 41032.
The hard coat 2186 buggy truggy exhaust from Ielasi looks funky but really nice. Have you tried it?
Old 09-30-2023, 01:41 AM
Trader Rating: 25 (100%+)
Throw a 2035 on it. I get them from reedy on eBay. Nasty pipe.
petersen114 and stanleyw808 like this.
Matt Piva is offline
Old 10-16-2023, 01:00 PM
Hi buddy.
85mm or 90mm header from O.S.
2090 pipe. Now called the TB02
This is the winning combo in my eyes. The TY 110% also come in this configuration out of the box. Absolutely epic power.
sn47som1 likes this.
Razenzo is offline
Old 10-18-2023, 09:16 AM
I have ran the 2090 in the past with a 75mm manifold and it was ok in my book. I ran it on a modded Spec 2 in a buggy and it was not bad but it inflated the midrange spike of that engine. The 2186 is a great pipe setup, I have ran it on a Muran B2104 and its an awesome all round pipe, amazing trigger feel and great overall power top to bottom and it sounds amazing..kinda like the 2013 but a bit smoother sound. Remember each pipe set will run different on each engine . As far as your 41032, if it doesn't have a M or L on it you have the standard. For truggy the Max 2164/Max GT L manifold is just amazing on a Roma and I'd suspect a Nova 28-7-8. The 41032/9886 or even the Hipex 2034 always performs better than most other combos.If you want low end snap and a decent top end and I mean decnet not a screamer the Picco 2046 or the RCR 2148 which I think is the same pipeset.If any pipeset pulls the wheels from a low speed throttle squeeze is that one.
Are you racing a truggy or are you ripping around and trying to extract as much power as possible ? Unfortunately you cant have your cake and eat it too so you ahve to decided what you want .
Old 10-18-2023, 12:48 PM
Blaster1's Avatar
OS based engines we run the Ultimate 2141 in buggy on most outdoor tracks/2142 on bigger, high bite indoor events. Truggy most times the Ultimate 2142
Blaster1 is offline
Old 11-27-2023, 09:24 PM
kruzracing169's Avatar
Originally Posted by petersen114
.............. When I was using Novarossi engine I used a 9901 and either a 41021 or a 41031 header depending on the track.
Which novarossi motor were you running with this pipe and headers?
petersen114 likes this.
kruzracing169 is offline
Old 11-27-2023, 11:32 PM
Goof's Avatar
Trader Rating: 81 (99%+)
It's been while..but I loved a 2096 with long 41005 header for nova I have 1 more to i just can't think of it
Lrp zz / 93 screamers r monsters
Rd2 /2060 for os
Hipex 2135/ L50
All good truck combos 4 me
Goof is offline
Old 11-28-2023, 03:34 PM
P5XLT, P5XLT-16-19, Keep Off, Plus 21, Mantra, etc. Even the Legend 25 responded well with the 9901/ 41031.
Old 12-05-2023, 10:05 AM
OffRoadJunkie's Avatar
The pipe you use depends on the track. The more you are wide open, the longer the stinger and header. Shorter tracks, you would want a shorter header and stinger. It's all about the timing of the back pressure to the cylinder.
OffRoadJunkie is offline
Old 12-06-2023, 01:18 AM
stanleyw808's Avatar
Hello OffRoadJunkie,
As far as I know, shorter Manifold will provide more Top End, while longer Manifold will provide more Torque.
Cheers..
stanleyw808 is online now
Old 12-06-2023, 10:13 AM
Cheers..
You got me confused there for a second, then I realized what I wrote. Yes, you are correct. I was smoking the good stuff when I typed out my response and had I it in reverse. I meant to say what you did. basically, it depends on your motors RPM sweet spot. The sonic back pressure needs to be timed just right.
