Like Tree3Likes
  • 1 Post By Nitro5270
  • 1 Post By jersey
  • 1 Post By J.Whiting
Break-in Fuel Oil
Old 12-06-2021, 12:30 PM
ceh329's Avatar
Default Break-in Fuel Oil
Hello, I have plenty of Fuel and I'm going to be breaking in a new engine. Its suggested that I use 12% oil for the process. I have a gallon of VP 30% Nitro 9% Oil set aside for this. What oil and how much should I add?
ceh329 is offline
Old 12-12-2021, 06:05 PM
https://blendzall.com/products/blend...60-green-label
Robert Ronas is offline
Old 12-14-2021, 04:46 AM
Nitro5270's Avatar
I recommend you to ask VP because nobody beside VP know what are really in there fuel.
Just be careful with fuel experiments.
It provide lots of fun to play with fuel but can caus havoc.
Nitro5270 is offline
Old 01-05-2022, 04:36 AM
Nitro5270's Avatar
Nat710 likes this.
Old 01-05-2022, 04:40 AM
Nitro5270's Avatar
This video is mainly
about ABN glow engines,
Old 01-05-2022, 12:23 PM
Somewhere online there is a nitro fuel calculator for nitro oil methanol etc. it will show you wjth how much oil you add your percentage. Iíll try to find it.
you can buy Klotz benol if you want more castor oil in the fuel. Or you can buy klotz techniplate If you want more synthetic and castor oil.
I run vp tessman blend 30 percent, this fuel has no castor oil in it so I add about 75ML klotz benol oil in the gallon so the fuel has some castor oil in it.
the regular vp you have has castor oil in it already so if you want to increase the overall oil synthetic and castor the klotz techniplate will do that.
Nitro5270 likes this.
jersey is offline
Old 01-05-2022, 12:51 PM
Roelof's Avatar
Why the need of a calculator?
If you take 1 liter of fuel then you just need 20ml of oil to get 2% extra oil
Roelof is offline
Old 01-05-2022, 04:09 PM
I suck at numbers lol 😂
jersey is offline
Old 01-05-2022, 04:22 PM
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 62 (100%+)
Oil Fuel Ratio
surprised roelof didn't just add this link as he normally does
but per my calculations in the past to get 2 more % in the oil its around 75ml of oil is what i recall. i used novarossi castor oil when i did add.
petersen114 likes this.
J.Whiting is offline
