can piston pin be reused?
Old 10-25-2020, 03:49 PM
Default can piston pin be reused?
i recently broke the connecting rod on my os 21tm, i know the piston pin retainers should NOT be reused but was wondering about the pin itself?
Steelers2424 is offline
Old 10-26-2020, 08:08 AM
Good question. I just rebuilt a reds 721 and reused the pin cause I forgot to order one. I measured the pin and there was next to no wear on it so I figured it’d be fine. I don’t know if it’s ok or not but so far so good.
Jcharger13 is offline
Old 10-26-2020, 10:22 AM
Trader Rating: 25 (100%+)
did it break threw the middle of the rod or in the bushing area? Highly unlikely it would happen in the top hole bushing but that would be one concern to reuse, also if the pin has any visible scratching I would have tossed it, however in a normal rebuild you can reuse the pin, I think most racers would replace all or just have a rebuild kit thatís fully built rod and pin so a lot of us may not even consider thinking about this piece. Itís up to the user as Iím sure plenty of people wouldnít have had an issue re using the pin in a rebuild. In a broken rod situation most would toss the engine because it causes unfixable damages. I broke a rod and know the piston was fine so that upper pin looking to work still, still I couldnít rebuild it because the sleeve was permanently stuck from the broken bottom rod piece slamming the bottom of the sleeve and spreading it wide. Destroyed everything. It was awesome. Thankfully happened on an old engine.
Matt Piva is offline
Old 10-26-2020, 04:42 PM
timjs's Avatar
I've never seen a wrist pin with significant wear.
timjs is offline
Old 10-29-2020, 06:07 AM
UrabusDenis's Avatar
I don't replace them unless there is no visible deamage. You can also just replace one clip when changing a conrod, because if you remove just one you can push the piston pin by using an hex screwdriver through the clip left. Then put a new one on the missing side and voila, it's secured.
UrabusDenis is offline
Old 11-03-2020, 06:48 PM
Thanks for the replies, i decided to play it safe and just replace it as well. pic below of the damage
Old 11-03-2020, 09:37 PM
thank goodness lmao it broke literally at the wrist pin. No way I would feel comfortable after that.
