Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Alternative to Lucky 7/AHZ Wicking Engine Sealant >
Like Tree1Likes
  • 1 Post By Roelof
Old 09-30-2019, 01:01 PM
frewster's Avatar
Default Alternative to Lucky 7/AHZ Wicking Engine Sealant
Hello,
Does anyone know of an alternative engine sealant similar to the Lucky 7/AHZ wicking kind? I have a friend in Canada who cannot easily get the AHZ sealant and the closest I can find is maybe the Permatex Spray Engine Sealant but I'm not sure if that would stand up to nitro fuel. I am looking for a wicking sealant that can withstand engine temps and not your typical silicone gasket maker sealant.
Thanks!
frewster is offline
Old 09-30-2019, 01:51 PM
Roelof's Avatar
But why? All current engines ar pretty well sealed with O-rings
J.Whiting likes this.
Roelof is offline
Old 09-30-2019, 02:26 PM
frewster's Avatar
My friend has an old Picco and is having trouble finding a replacement o-ring.
frewster is offline
Old 09-30-2019, 10:56 PM
which picco does he have. PiccoAmerica.com tritonrc.com probably both have something that will work
jersey is offline
Old 09-30-2019, 11:00 PM
frewster's Avatar
He has a Picco Boost .21 5TR and it has an airleak around where the carb goes into the crankcase. Once it gets to temp it dies no matter what the tune.
frewster is offline
Old 09-30-2019, 11:22 PM
Roelof's Avatar
On ebay you can find sellers with all kind of dimensions of silicone O-rings and if you look arround you can find a cheap box with all kind of sizes.
But you are sure it is an air leak? What you discribe sounds to me as a worn P/S set.
Roelof is offline
Old 09-30-2019, 11:42 PM
go on piccoAmerica.com or Tritonrc.com
the orings for triton carb work fine on picco. Same with the newer picco carb gaskets they work fine.
jersey is offline
Old 10-01-2019, 08:15 PM
Thanks I have been looking for that product
Chris Reilly is offline
