Like Tree3Likes
OS Spec II equivalents
Old 08-14-2019, 02:14 AM
Default OS Spec II equivalents
Hi, after a bit of advice please.
Are there any engines still made that are based on the OS Spec II?
What about the Tekno RC BLOK 21aP or the Ultimate M3S?
Thanks!
Redtopracer is offline
Old 08-14-2019, 05:40 AM
ZEe_NYC's Avatar
Trader Rating: 55 (100%+)
XZB spec II or the VZB spec II?
Protek samurai is a vzb
ZEe_NYC is offline
Old 08-14-2019, 06:09 AM
Thank you, i should've specified XZB spec II
Old 08-14-2019, 09:43 AM
am
OS Ty tessmann II with the large cooling head is a spec II.
Rutters likes this.
am is offline
Old 08-14-2019, 09:44 AM
am
https://www.ebay.com/itm/O-S-Speed-1...-/273277015908
am is offline
Old 08-14-2019, 09:47 AM
I am pretty sure the blok is a spec 2 and the flashpoint is a spec 2 with a plain crank instead of the dlc coated crank.
windellmc is offline
Old 08-14-2019, 10:08 AM
would anyone mind explaining me the difference between the XZB and the VZB? Thanks!
xlrsd is offline
Old 08-14-2019, 03:13 PM
1/8 IC Fan's Avatar
Trader Rating: 96 (100%+)
VZB is the older generation motor, XZB the newer.
In other terms, VZB crank pins wear out prematurely, XZB series is just fine.
1/8 IC Fan is offline
Old 08-14-2019, 07:13 PM
Trader Rating: 127 (100%+)
VZB Speed is the short stroke DLC crank
VZB vspec (non speed) no DLC crank...different timing
XZB SPEED is long stroke DLC crank
XZB (non speed) no DLC crank
XZB speed SPEC II & SPEC III....long stroke DLC crank....
Lost track from there on....square bore and stroke etc....yadda yadda
Motorman007 likes this.
Neesh is offline
Old 08-14-2019, 10:15 PM
Also those flashpoint engines are spec 2s I heard but without dlc and fancy stuff carb etc.
edit saw it was already posted above
jersey is offline
Old 08-15-2019, 12:06 AM
So the XZB would be the one to go with. Lol thanks for all the explanation guys! But from what I understand, this engine is no longer made, or at least discontinued by OS? At least the Spec 2 version, right?
xlrsd is offline
Old 08-15-2019, 02:19 AM
That is why I started the thread
I don't think OS sell it under their own brand any more, but it appears they still produce it for other brands, or the other brands have stock still.
From what I have read it's one of the most brutal engines out there.
Old 08-15-2019, 01:44 PM
am
Again:-) - , the engine i linked to IS A VZB Spec 2... Plenty araound still if this is the engie you wan`t.
am is offline
Old 08-15-2019, 02:15 PM
1/8 IC Fan's Avatar
No, OS do not offer it anymore. And unfortunately since Horizon took over OS distribution in the US, their tech support will not be the best or most helpful. To bad the OS (US) site is no more
Old 08-15-2019, 07:13 PM
sorry bud, that link is to a XZB speed specII Ty edition
Neesh is offline
