Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Losi 8ight won't start wheels dont disengage >
Like Tree3Likes
  • 1 Post By timjs
  • 1 Post By JakeS924
  • 1 Post By RCTecher12
Old 06-20-2019, 02:11 PM
Default Losi 8ight won't start wheels dont disengage
I have a Losi 8ight RTR. When I try to start it the wheels start spinning. I think it is a clutch problem but I'm not sure. Any help would be nice . Thanks Mike
MikesLosi is offline
Old 06-20-2019, 03:16 PM
timjs's Avatar
You're probably right. Take the engine off and remove the clutch bell. You'll likely see either the clutch shoes/springs are somehow dragging the bell OR a bearing have seized and did a number on the crankshaft as well.
J.Whiting likes this.
timjs is offline
Old 06-20-2019, 04:30 PM
Thanks, I was getting ready to remove engine and clutch. I will follow up with what I find.
Old 06-20-2019, 06:49 PM
JakeS924's Avatar
Sounds like a similar issue to what happened to me a couple months ago. Check the clutchbell bearings, mine exploded and wouldn’t disengage the clutch from the engine
JakeS924 is offline
Old 06-21-2019, 02:25 AM
Likely a clutch spring that broke. Replace the clutch bearings while you’re at it.
RCTecher12 is offline
