Like Tree1Likes
  • 1 Post By 1/8 IC Fan
Clutchbell bearings
Old 04-18-2019, 01:24 PM
JakeS924's Avatar
Default Clutchbell bearings
Installing new bearings for the clutchbells on both my tlr 8ight 3.0 and 8ight-t rtr today. How should I oil them or what should I do before throwing them in?
JakeS924 is offline
Old 04-18-2019, 02:22 PM
As far as I know, you donít need to oil them or anything it all. They come pregreased and sealed. More importantly, clean out the bearing housing they are inserted in to really well. And while youíre at it, clean the inside of your clutch best you can. File burs on shoes, etc.....
xlrsd is offline
Old 04-18-2019, 02:24 PM
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
Leave them alone, buy spares bearings. You add any oil and you will kill your shoes!
petersen114 likes this.
1/8 IC Fan is offline
Old 04-18-2019, 03:44 PM
petersen114's Avatar
Yep.
petersen114 is offline
Old 04-19-2019, 02:15 PM
I clean my clutch bells with carb cleaner and then wipe them dry with clean rag (sometimes the carb cleaner leaves a film).
I wipe any oil off the outside of the inside bearing so it doesn't sling oil into the inside of my clutch bell.
GripTLR is offline
Old 04-23-2019, 01:15 PM
houston's Avatar
Trader Rating: 96 (100%+)
denatured alcohol is your friend
15$ gallon ..... much cheaper than spray can carb cleaner as well ...
houston is offline
Old 04-23-2019, 01:57 PM
Check our Avid Bearings. $1 each. Been running them for years with no issue. I change them out before a big race or a couple of club races.
token is offline
