Like Tree1Likes
  • 1 Post By GripTLR
Need help
Old 04-14-2019, 07:28 PM
Default Need help
We got a traxxis t max .15 need some one to help us .. The even ia off because it needs a ome way barring for the pulley .... Was wondering if there is a way to check the transmission with the engine off the spur gear turns freely in both directions .. Were new to them dont really know anything about them please help
Eboyy is offline
Old 04-14-2019, 10:15 PM
Breath, then re-type that entire thing so other human beings can read it.
frewster likes this.
GripTLR is online now
Old 04-15-2019, 12:58 AM
TheWorstDriver's Avatar
TheWorstDriver is offline
Old 04-15-2019, 07:42 PM
jhold87's Avatar
Trader Rating: 12 (93%+)
Default .....
Good way to welcome someone new to the hobby.
jhold87 is offline
Old 04-15-2019, 07:47 PM
jhold87's Avatar
Default Transmission
If the spur is turning free you should be good, the T- MAXX has a pretty tough transmission. I ran about 6 gallons through mine and never replaced anything in the transmission.
jhold87 is offline
Old 04-16-2019, 08:05 AM
it wasn't disrespectful at all....it literally cannot be understood. You made an attempt at it...
if anything I think you were more disrespectful by assuming he is new to the hobby because he has 2 posts on these forums.
Old 04-16-2019, 08:19 AM
Does it have a pull start?
Or is it the plug in electric start version.
If I recall correctly, both had a one way bearing on the output shaft of the motor for starting. If that oneway needle bearing got lubrication/oil/grease on it, it would slip and prevent the starter from turning the motor over.
I usually corrected that problem by taking it apart and giving is a shot of brake cleaner (NOT WD40, as that makes matters worse).
Nitro vehicles are AWEFUL to troubleshoot from a computer.
I highly recommend finding a hobby store, and asking for help..
Even if there is an model airplane club nearby, the glow engine technology is the same. Its nothing but glow plug, voltage, fuel, mix, and compression. If you make sure you have those things, the last bit is experience/.
Good luck
simple is offline
