Setting up the clutch shims
Old 03-01-2019, 11:03 PM
Default Setting up the clutch shims
So on the MP9 tki4 manual is saying to install the big shim inside 5x20x0.2mm and after install the smaller one 3x5mm. I have seen videos that people use the smaller shims only and not the big one. So what is the difference?
Thank
Niz55 is offline
Old 03-02-2019, 02:16 AM
Roelof's Avatar
The big one is probably a kind of dustcap to prevent clutch dust coming into the bearings. Because this it the only one using such a large shim I can imagine people are not using it.
Roelof is offline
