Like Tree1Likes
  • 1 Post By HaulinBass
Brand New reds WRX motor seized.
Old 02-28-2019, 07:59 PM
Default Brand New reds WRX motor seized.
Hello,
​​​​​​I just installed this motor in my car and fired right up for 10 second and cut out afterwards. I tried starting it again and the flywheel is stock. I took off the motor and took the clutch and flywheel off and everything is perfect. I noticed some oil coming out the front bearing and crank has about 2-3mm movement in and out. I tried spinning the crank and it makes a metal to metal noise.
I also took off the carb and noticed bunch of orange color silicon or something else stock on the crank. Please see picture.
Niz55 is offline
Old 02-28-2019, 08:11 PM
You said flywheel is stock. I think you meant stuck?
sometimes need engines get stuck when breaking them in if they have a lot of compression. Preheating engine helps wjth that. As far as the orange silicone thatís normal, a lot of crankshafts have silicone inside of them. I guess your new to nitro.
Watch this Ryan lutz break in video. He shows how flywheel sometimes gets stuck.
watch this Adam drake break in video also
watch this Ryan lutz tuning video.
Also watch this drake linkage video.
watch all this stuff first before continuing. These videos help a lot.
jersey is offline
Old 02-28-2019, 08:16 PM
HaulinBass's Avatar
Trader Rating: 14 (100%+)
Its just super tight at Top dead center heat that sucker up.
HaulinBass is offline
Old 02-28-2019, 08:20 PM
I pre heated the motor and all good.lol
Niz55 is offline
Old 02-28-2019, 08:32 PM
HaulinBass's Avatar
then you didn't instal the flywheel correctly, allowing the crank to rub against the backplate.
pull off the flywheel,take off the backplate and push the crank forward,while pushing the crank forward make sure the collet is seated against the front bearing and reinstall the flywheel. do you still hear the grinding sound?
jersey likes this.
Old 02-28-2019, 10:07 PM
yes do this!
jersey is offline
Old 03-01-2019, 01:57 AM
Everything is fixed guys. It took me 6 times to pre heat the motor and it started up finally. Did the break in already and tommorow will be tunkng it.
Niz55 is offline
Old 03-01-2019, 03:10 AM
Stealthwave888's Avatar
glad it worked out for you mate , what a bummer other wise.. pre heat to about 80 c is what i used to do , getting back to getting some dirty fun after a bit of a break..
wishing you well and lots of fun .
Stealthwave888 is offline
