Os speed .21 piston and sleeve
Old 01-09-2019, 05:17 AM
Default Os speed .21 piston and sleeve
Has anyone ever tried the replacement piston sleeve and rod off eBay itís aftermarket and a good bit cheaper
Bigdawg2251987 is offline
Old 01-09-2019, 10:56 AM
tom1974's Avatar
dove trovi su e bay aftermarket os?
ball bearing??
tom1974 is offline
Old 01-14-2019, 05:30 AM
i have. It's a Taiwan low quality p/s/r with a very high silicon content piston. It'll run but won't last as long as the OS. Rod and bushings wore prematurely on mine.
stephen_bess is offline
Old 01-15-2019, 11:20 AM
RCAlex187's Avatar
It will probably run but i do not know about reliability,power and ease of tune.
RCAlex187 is offline
Old 01-16-2019, 02:12 PM
Trader Rating: 20 (100%+)
I would atleast stay away from there rod. If a piston or liner fails itís just a replacement but if your rod fails in the slightest you end up with a catastrophic destruction inside. Not worth the risk.
Matt Piva is offline
Old 01-16-2019, 03:48 PM
Roelof's Avatar
Why be carefull ??????
It was already a worn out motor giving a 2nd life with an alternitive P/S set. And because an offroad is not running high revs even cheap Force/Go/SH rods will work fine.
But is there a link to the P/S set?
Roelof is offline
Old 01-16-2019, 07:12 PM
E1 Diablo's Avatar
My guess
https://www.ebay.com/itm/O-S-21-21XZ...0RGm:rk:9:pf:0
E1 Diablo is offline
Old 01-17-2019, 01:06 PM
Roelof's Avatar
Nice but not that cheap. With a same price once I bought a 3 port Novarossi P/S/R set.
Here some reviews for what it is worth
https://www.ebay.com/itm/OSM22103030....c100008.m2219
Just 1 whiner about a too tigh pinch
Roelof is offline
Old 01-17-2019, 10:33 PM
Juice1's Avatar
Trader Rating: 16 (100%+)
Or you could just use a p/r/s replacement set from an Atom engine from Dialed RC. Get the SV-1 set for long stroke Xzb engines or the Vortex for Vzb engines.
Juice1 is offline
