View Poll Results: oil content
9% oil
18
52.94%
11% oil
16
47.06%
Voters: 34. You may not vote on this poll
fuel oil percentage
#16
It actually says on Byrons website that they get "custom designed oil package from Klotz".
Byron Originals-Champion RC Fuel
If you calculate the max RPM into speed of the piston and surface speed of the crankpin it is nothing more than with larger motocycle and car engines, the only difference is the lack of a piston ring. That is why some kind of transmission oils are also used by some home brewing people.
#17
25/9 VP for me!
#18
From what we have used over the years it would not supprise me that it is just normal oil with another lable.I do not believe that "special for RC" crap as most oils and grease used in the RC are just re-bottled standard oils. But hey, if you tell that no one would buy it.
That's one reason why many oils has unspecified oils in them, they mfg that blend the final product knows there are several types of oils that will meet the specification, so they buy what's cheapest at the time.
Though Ester oils tend to be more specifically made for a purpose, that's kind of their strength, that they can be tailor made for specific use. But then they are too expensive, so pretty much no RC fuel mfg offer them, good enough will do if they can save a buck.
#19
i must not have been paying attention ..... it use to be synthetics from Lucas oils
Ryan sent me some GEN3 version of fuel for test but it didnt quite stack up .....im guessing this is when the change happened .... sooo late 2017 early 2018
#20
Great that they test the fuel thoroughly before releasing it, there is several fuels that should have gone through the same screening process but didn't.
#23
It goes to show that it's a lot more to it then just pouring stuff in a jug and shake it. It can work for your backyard driving, but not when everything needs to come together on a race track.
#24
My experience is that 9% oil veras the engine out faster than 11. That is Byron fuels. I bought 2 cases of 25/9 beacuse an engine manufactor adviced it. I was not satisfied and my engines started wearing faster. I used three engies taht seaaong from Nova. (they were not behind the Byron statement). I ended up using 2% Castor from the pharmacy and it gor alot better.
#25
For all out racing sometimes a gallon more or less from the engine isn't a big deal as well, if you get a stable running engine, good power, good runtime etc etc. As long as you find something you're happy with all is good.
#26
The best fuel i have ever used is Labemax from France. very very VERY smooth engine and easy to adjust. good top speed. Better runtime too. Byrons is a good fuel but feels explosive and brutal compared to Labemax.
#27
And I feel the opposite, that Byrons might be a little bit too smooth. If you feel that the engine has too much torque and wants to spool too easy, just dial it back on the clutch and other setups. But it can be driver difference as well, if you gun it all the time I can see your point.
#28
#29
In most cases a bad fuel will wear down the crank pin. So with some of the fuels on the market, maybe it isn't so strange that we see more and more DLC being used...
#30
About wear
I think the impact of air filter is much higher than the oil cut
