Buku Clutch Shoe Usable?
Old 08-18-2018, 11:16 AM
R/C Tech Elite Member
CBren32's Avatar
Default Buku Clutch Shoe Usable?
So, was having some issues with the Revo, notices the clutch bell was loose so went it and found this clutch shoe with a clapped out back-side. Want to know if it's usable still, or if I should just get a new shoe? Also, what could I do to prevent this? I suppose I can loosen the shoes up some, but they weren't THAT tight.
CBren32 is offline
Old 08-18-2018, 11:20 AM
CBren32's Avatar
No never mind, not sure why I posted this. It's not usable, probably best to just see if I can get a new shoe. Kinda stinks. I can see the other ones wearing in the same spots as well...is this a known issue?
CBren32 is offline
Old 08-18-2018, 05:40 PM
Is that the whole clutch set up from Buku or just shoes? I run their clutch(not revo) and have never had a problem.
brokenmoto is offline
Old 08-18-2018, 07:19 PM
CBren32's Avatar
Yeah, I think somehow to bearing came loose causing it to slide down some and wear the inside of the shoes. I knew it had some problems with the clutch, but took it out for like a tank a few days ago and I suppose that's where most the wearing happened. Wish I could buy individual shoes, but it's fine. Lesson learned, more shims, looser shoes, and better bearings. Of course it happens when most my rigs are having issues. Hopefully I can get this Serpent Truggy built in a few days
CBren32 is offline
