Novarossi p3 xs tuning
Old 08-08-2018, 03:58 PM
Default Novarossi p3 xs tuning
Hi my mame is josh i dont really sign up to forums. I have look all over the net for my help but i dont think i can fine it without asking personally.
I have bought a novarossi p3 xs serpent engine. I have put it in my hyper 7 and i broke it in with factory settings. Then i took it to the shop and he tuned it to 16% all was fine but i tried to start it a couple of days later and it wouldnt idle and kept cutting out after 2 seconds. If i gave it some throttle it would stay alive. I gave it a good run like one tank and abit and it had an extremly high idle and just wanted to keep moving without applying the brake. I know this aint normal so i cut it out and looked at the glow plug and it was black. I have looked at tuning guide but i cant seem to get it right. I can ever get it so judders on idle or high rpm after a run and wants to take off if lifted up. Can someone point me in the right direction please thank you.
Rustyuk is offline
Old 08-08-2018, 04:13 PM
22Racer's Avatar
Trader Rating: 67 (100%+)
Set idle gap at .7mm(.030") lsn should be flush and hsn maybe 1/2 turn in from flush. That might be close to start with but a little rich on hsn.
Rex
Rex
22Racer is offline
Old 08-08-2018, 04:21 PM
Roelof's Avatar
Did you replace the plug? That it was black could be from the rich break-in and wit a normal break-in you will end up with the need of a new plug.
Roelof is offline
Old 08-08-2018, 04:22 PM
Rex
Rex
Thanks for the quick reply i will try this tomorrow and i will get back to you.
Rustyuk is offline
Old 08-08-2018, 04:24 PM
Hmm.. No i never thought of this, maybe your right. I will replace the plug and try this aswell. Thank you
Rustyuk is offline
Old 08-09-2018, 11:53 AM
After a good 20mins i have given up. I have read countless tuning guides. But at this point i just wanna smash it in the wall. I think i am just going have to take it back to the shop. I am a proper DIY guy but i think i am just going to have to admit defeat.
Thanks for your help guys
Rustyuk is offline
Old 08-10-2018, 09:58 AM
houston's Avatar
Trader Rating: 96 (100%+)
have you tore the engine apart?
houston is offline
Old 08-10-2018, 10:53 AM
savage24x's Avatar
Sounds like a rich LSN and too high of an idle.
savage24x is offline
