Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Engine with metalic ringing sound >
Old 07-24-2018, 04:19 AM
b3master's Avatar
Default Engine with metalic ringing sound
I have an .21 sh engine that was put aside for a week, that i had droped in some atf, for lack of anything else...
now i installed it back in my buggy, where i was breaking in another engine, and now i have metalic ringing sound that goes away when i hold the cooling head, i hoped it was the clutch bell or sloppy untightened motor mounts or even exhaust too close to manifold, but nope its the engine. Seems like bad rear bearing so i tore it apart but the bearing is smooth as silk and no signs of a bad rusty ball or anything... might have developed some slop that is so minute i cant feel..
is it okay to keep running the engine? Or do i wait for new replacements to arrive?
its running like a champ just ringy, so idk
b3master is offline
Old 07-24-2018, 04:25 AM
Roelof's Avatar
Probably a crack in one of the cooling fins of the head
Roelof is offline
Old 07-24-2018, 05:58 AM
b3master's Avatar
thanks for the suggestion, went right out and switched the head with another same. Im afraid it didnt do much difference..... is there a way to confirm failing rear bearing? Could the atf have any ill effect on the engine internals?
b3master is offline
Old 07-24-2018, 09:30 AM
It's usually the bearings that is bad when what you describe happens. Just change them.
NitroVein is offline
Old 07-24-2018, 12:11 PM
HaulinBass's Avatar
Trader Rating: 14 (100%+)
Try putting on a glove and holding the cooling head with the engine running, if the sound goes away when you do the bearings are probably shot
HaulinBass is offline
Old 07-26-2018, 07:12 AM
b3master's Avatar
Another motor in another buggy that i had also put in that same atf in it for weekly storage also was giving me similar sound that goes away when i hold the cooling head, either this atf is ruining the rear bearing ball retainer, or im being too sensitive to cooling head resonance or rattles..... ill order replacement bearings and keep an ear out for the engines....
b3master is offline
Old 07-26-2018, 11:05 PM
Rear bearing 99 times out of 100.
stephen_bess is offline
Old 07-27-2018, 12:39 AM
Roelof's Avatar
When a rear bearing is worn out you will get a kind of a white noise, no ringing sound.
Roelof is offline
Old 07-27-2018, 01:40 AM
b3master's Avatar
yes, thanks for the clarification and proper discription, its not clinking not clunking not precisely rattling and not ringing, its a white metallic hiss noise
so if applying the oven heating method how important is it to replace the front bearing since it undergoes the heat, and if there is a O ring inside the carb opening whats the best practice of removing it?
Could this have happened to both engines from using that ATF or could it be just coincidence or because of using same fuel and storing for similar amount of time...
b3master is offline
Old 07-27-2018, 05:01 AM
timjs's Avatar
The "white noise" description is spot on.
Replace both bearings, the front isn't immune to wear. But, the heat doesn't hurt it in my experience. I use 300f in the oven for bearings. Sometimes more if they're stubborn.
I use a regular ol' pick for removing the O-ring, but it's probably fine to leave in there.
I don't see how ATF could damage a bearing.
timjs is offline
Old 07-27-2018, 07:53 AM
Roelof's Avatar
Hopefully no voices are comming through with it :P
Roelof is offline
