Novarossi Mito engine question
Old 07-15-2018, 01:49 PM
Default Novarossi Mito engine question
I have a new engine for my offroad buggy, and since I've never used Novarossi before, I have a question?
The engine came with 2 small tension springs which, I believe, are used to keep the throttle closed. However, unlike other engines the spring is short and I have no idea how to use it; attached the exploded view of the carburator. The spring p/n is 60007
Any guidance will be appreciated.
Thanks.
File Type: pdf
kwhunter is offline
Old 07-15-2018, 06:06 PM
Those are exhaust springs.. To hold the manifold to the engine.
iplaygames is offline
Old 07-15-2018, 09:28 PM
Thanks; however the manifold came with it's own long spring. So I have 2 short spares now. But no spring for the throttle
kwhunter is offline
Old 07-16-2018, 04:37 AM
Roelof's Avatar
It is wise to mount both. All manifolds have the option to mount 2 springs, it is extra safe in case one spring snaps off.
The short springs are hold by 2 small "ears" on the crankcase
Roelof is offline
Old 07-16-2018, 05:48 AM
Thanks for the tip.
kwhunter is offline
Old 07-20-2018, 07:02 PM
rceefreak's Avatar
Trader Rating: 153 (100%+)
I use both the short springs and the long one. Extra security like someone above said
rceefreak is offline
