Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Can front bearings be reused on a different motor? >
Old 05-21-2018, 01:20 AM
b3master's Avatar
Default Can front bearings be reused on a different motor?
When heating a motor in the oven 300-400°f to remove the bearing are the bearing seals still good enough to be reused?
is there a different way to remove if i intend to reuse?
b3master is offline
Old 05-21-2018, 01:44 AM
https://www.amainhobbies.com/hudy-ul...107051/p179865
Something like that can pull out and reinstall bearings without healing the snot out of them, in which case you could reuse.
Gavel is offline
Old 05-21-2018, 01:51 AM
Roelof's Avatar
Still you do need to add some heat so the hole size in the crank case will not get damaged
But with a lot of heat the only part in a bearing that can get damaged is the plastic ring holding the balls. If that one is still in shape holding the balls on the place then yes, you can re-use the bearing.
Roelof is offline
Old 05-21-2018, 05:13 AM
As long as the bearing makes zero noise when spinning it dry. If it makes even the slightest bit of noise, replace it. Really though, if you’re removing a bearing from the crankcase - for any reason - why not just replace it? Peace of mind that you don’t need to tear the engine apart again in a gallon is worthwhile to me.
Edit: to add; heat is best. However you shouldn’t need to get any hotter than 350F to get the bearings out, and it is best to heat he case evenly - in an oven or something of the like. This ensures the bearing seats completely.
RCTecher12 is offline
Old 05-21-2018, 08:28 AM
Roelof's Avatar
If it is about a standard 7x19x6 bearing, you can get them for a few bucks from a bearing shop.
Roelof is offline
Old 05-21-2018, 10:30 AM
b3master's Avatar
just checking out my options, couldnt find any bearings in my country and seeing what options i had if i dont want to wait 6 or so weeks for replacement to arrive.... just curious
the straight forward answer is no, since there is a plastic part holding the balls apart that shouldnt deform in any way shape or form its better to say no i cant heat the engine without risking warping the plastic, i didnt know that was plastic i thought they are held with metal i was worried about the rubber seals since thats the reason im replacing it in the first place! The original one was leaking since i bought it... didnt want to risk buying a second motor only to discover it also leaks air...
you mean an online bearing shop? Or a local bearing shop? Is there such a thing as a purely local bearing shop?
ill try to find an online bearing shop that ships internationally...
Are the rear/inside bearing balls also held by plastic?
b3master is offline
Old 05-24-2018, 05:40 AM
grizz1's Avatar
Avid Bearings in the US. Quality bearings for RC engines and cars. Cheap and fast shipping. Google them up.
grizz1 is offline
Old 05-24-2018, 06:29 AM
Roelof's Avatar
As mentioned, it is a standard size and because of that cheap to get:
https://www.ebay.com/itm/10pcs-7x19x...kAAMXQMTlRbAmr
Roelof is offline
