Like Tree1Likes
  • 1 Post By GREGORY!
FX royal K5 internals
Old 04-08-2018, 10:15 AM
Default FX royal K5 internals
Where can I get internals for this engine and are they any Good? Thanks
derbrylac is offline
Old 04-08-2018, 02:31 PM
THE PHILLY JYNX's Avatar
k501r.....If your dlc crank is good drop it In 501r and go. $199
THE PHILLY JYNX is offline
Old 04-08-2018, 02:34 PM
Trader Rating: 52 (100%+)
www.rcamerica.com maybe
underway is offline
Old 04-08-2018, 06:21 PM
Originally Posted by underway View Post
Thank you
Old 04-11-2018, 09:31 PM
22Racer's Avatar
Trader Rating: 67 (100%+)
What parts are you looking for?
Rex
22Racer is offline
Old 04-20-2018, 08:17 AM
invrtd's Avatar
Trader Rating: 25 (100%+)
Is there a difference between the 2 engines other than DLC coated crank? Might be interested in picking one of these motors up Rex. Just would need a mod for GT.
invrtd is offline
Old 04-20-2018, 08:53 AM
Trader Rating: 21 (100%+)
Not sure if ports are different but the coated crank is more then just a coating, itís a defining modification which is the reason for the price gap. I do not run engines without dlc coated cranks because they wear out to fast (maybe how I drive? Idk) but I have seen atleast 5 of my old engines with demolished rod bushings and crank pins and itís pretty obvious when my ninja bo1 still has a fresh rod and crank after 6 years of use, it hasnít had pinch in forever but still runs good. I was lucky with a few engines to get 4-5 gallons (os.28, picco) before they were damaged from rod pin wear. Iím pretty hard on the gas all the time like Iím riding a stock cr125 at southwick. Lol
Matt Piva is offline
Old 04-20-2018, 04:57 PM
501r with 5k dlc cranks runs awesome FYI
Old 04-24-2018, 03:43 PM
invrtd's Avatar
Matt,
I love DLC coated cranks. I have a Ninja B02 that has been rebuilt more than once and an OS VZB speed 2 that keeps on going. The DLC coating makes a huge difference on wear. I would pay the extra for DLC knowing I can rebuild it with confidence. Even the DLC coated engine has a good price for around $379. Can't touch an OS for that price.
invrtd is offline
Old 01-28-2019, 09:27 PM
TheWorstDriver's Avatar
Picked up a 5K DLC for the race buggy and a 501R for practice, Anyone running these for 2019? Or is everyone running the Ty OS Speed these days? LOL.
My favourite combo so far after break-in is the 5K DLC and the Reds X-one 2104 pipe. I bet nobody has tried that combo yet!
TheWorstDriver is offline
Old 03-08-2019, 02:40 AM
GREGORY!'s Avatar
Matt,
I feel the same.
With dlc crank you always have the correct stroke, compression and timing.
and if you want,you can rebuild the upper area and have and engine like new.
TheWorstDriver likes this.
GREGORY! is offline
