OS spec II parts
Hey, I have a BLOK engine (spec II) that needs a cooling head mostly for cosmetic reason, top cooling fin is bent. I'm wondering what cooling heads are compatible. Curious to know if I can put a LP head on it?
What other engines would have the same piston, sleeve and rod? (if any) I'm on the fence whether to rebuild or just buy a new one. thanks |
Hello nodrog,
If the underhand is the same diameter as the Spec 2 which is 37mm, the LP Head of B2102 or Tessmann 2 should fit. Cheers.. :)
Originally Posted by nodrog
(Post 15148010)
