Like Tree4Likes
  • 4 Post By jkas10
Pipe Question
Old 11-30-2017, 07:20 PM
hillbillyrcer's Avatar
Default Pipe Question
I am running a RC8.2 Nitro with a OS .21 XZ it has a Jammin JP-4 pipe. Is that a good pipe or should i get a OS 2090 pipe.. I have read the 2090 pipe is the best for performance for the .21 XZ Max.... My engine runs great and has plenty of power it does seem it is louder than the last RC8 Nitro i had.... I dont really like the look of the pipe i have eather..
I might do some racing next season but probably not alot...
hillbillyrcer is offline
Old 11-30-2017, 07:53 PM
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 84 (100%+)
The JP4 will serve you well. Yet for racing, when you are trying to get the best tune, and fuel mileage a 2090 will be best.
Also what .21 XZ? the B, or B version II?
look in the BST forum, might find a used one.
1/8 IC Fan is offline
Old 11-30-2017, 08:47 PM
How can i tell what version i have??
Old 11-30-2017, 08:51 PM
Here is a couple of pictures of my engine. Took it out to clean up buggy...
Old 11-30-2017, 08:56 PM
Super Moderator
1/8 IC Fan's Avatar
XZ-B VII it seems.
Old 11-30-2017, 09:01 PM
XZ-B VII it seems.
Sorry for some reason I canít upload a second picture..
Old 11-30-2017, 09:05 PM
All it says on the top of cooling fins XZ Max Power
Old 12-05-2017, 10:05 AM
It appears to me that you have version one of the XZB blue which is a great engine. The Version 1 had the three needle carb and had plenty of power for me. I also had the JP4 pipe and that is a great pipe for your engine. My current XZB blue head has the newer 2 needle carb and I have not run it yet. I have it mounted in my brand new TD DNX8.
good luck
Michael
stoney452 is offline
Old 12-05-2017, 10:49 AM
I think the JP series pipes are fuel hogs... just my opinion. Ill take the 2090 over it any day.
token is offline
Old 12-06-2017, 12:42 PM
jkas10's Avatar
Trader Rating: 123 (100%+)
For real, though. If you are not yet racing, keep running what you have. When you do start racing, keep running what you have until you can run a five minute qualifier without getting marshalled at all. (or at least not frequently). Save the money for a new pipe and use those $$$ for track time, tires, or fuel to keep running laps. Basically, I recommend spending money on things that will get you on the track and driving as much as possible. Only spend money to replace broken or worn out parts, not to replace parts you already have. There will be plenty of time for that later as your racing program progresses. :-)
jkas10 is offline
