Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree374Likes
Old 09-15-2009, 11:54 AM
  #1351
Canyon's Avatar
Trader Rating: 8 (91%+)
Originally Posted by tutankhamen
Going to show my ignorance here.. Wanting to run spec class, using a 68 camaro body( i know how original), can I run Roar VTA tires and wheels? If my understanding is correct spec class is vta and rcgt? Buying tires today and don't want the wrong ones.
Grant
Yeah the ROAR rules just state that they have to be a trans am era treaded replica. The ones that the Hangar has decided to use for their control tire is the HPI. We've got them in stock out at the shop.
Canyon is offline
Old 09-15-2009, 12:25 PM
  #1352
corallyman's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Goingfast
I'm thinking about bring out my 12th scale ,So what's the hot ticket tires set up and rolll out? thanks
Brian's combo last year on our Paragon track was Jaco 2xPink fronts and either yellow rears or pinks. We may try other tires this year but this should get you in the ball park. I think we were rolling out around 88. If Brian see's this he will correct me if I am wrong. For body, he was liking the Protoform Speed 12.
Steve
corallyman is offline
Old 09-15-2009, 12:28 PM
  #1353
mkdut's Avatar
Trader Rating: 19 (100%+)
Your guess is as good as mine. I am sorta in between cars right now and this is my first run with 1S. I would guess Pink/2xPink will be a good place to start. I have no idea on rollout.
mkdut is offline
Old 09-15-2009, 01:02 PM
  #1354
Canyon's Avatar
You could say I was slightly bored this morning.
http://twitter.com/RCHWoodinville
Canyon is offline
Old 09-15-2009, 01:08 PM
  #1355
PutAwayWet's Avatar
Franko,
Speedmerchant 1S, yes?
If so:
Pink R/Dbl Pink F
45mm/43mm
front sidewalls rounded, no CA, 15 min dope all around, full rear, 2/3 front
4mm ride height
start at an 85mm rollout.
PutAwayWet is offline
Old 09-15-2009, 01:16 PM
  #1356
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by corallyman
Brian's combo last year on our Paragon track was Jaco 2xPink fronts and either yellow rears or pinks. We may try other tires this year but this should get you in the ball park. I think we were rolling out around 88. If Brian see's this he will correct me if I am wrong. For body, he was liking the Protoform 12.
Steve
Goingfast is offline
Old 09-15-2009, 01:18 PM
  #1357
Goingfast's Avatar
Dang.....I don't have the 1S lipo yet....I might have to run the 4 cell this weekend or sedan stock
maybe I can borrow one (1S lipo)
Old 09-15-2009, 01:19 PM
  #1358
Goingfast's Avatar
Originally Posted by PutAwayWet
Franko,
If so:
Pink R/Dbl Pink F
45mm/43mm
4mm ride height
Great job todd....Thanks
Old 09-15-2009, 01:22 PM
  #1359
mkdut's Avatar
Franko,
If so:
Pink R/Dbl Pink F
45mm/43mm
4mm ride height
85mm? Seems kinda tall though seeing how I have no idea it may be OK.
mkdut is offline
Old 09-15-2009, 01:32 PM
  #1360
PutAwayWet's Avatar
I was running a Novak/TC Spec power package. But I'm pretty sure even Bodine with the Duo/Tekin combo was in the mid-high 80's. 85mm definitely should be a reasonable place to start. In general, gear up with the voltage drop from 4-cell to 1S.
Old 09-15-2009, 01:37 PM
  #1361
mkdut's Avatar
We shall see. I think I may go a little bit conservative the first few runs and keep an eye on motor temp.
mkdut is offline
Old 09-15-2009, 01:51 PM
  #1362
Trader Rating: 37 (100%+)
Franko,
If so:
Pink R/Dbl Pink F
45mm/43mm
4mm ride height
Based on what Todd, Brian, and Korey have advised me....and on the recent practice day this is perfecto!
I was rolled out in the low 90's (coming off at 140F after dumping the pack, had no lower T pinions) and hitting "2nd gear" in the last 1/3 of the back straight. A couple/few teeth lower to the high/mid 80's would do the trick!
Have some new yellow rears to try out...all I've ever tried are pink rears and purple or dbl pink fronts.
jubilee is offline
Old 09-15-2009, 04:15 PM
  #1363
oldrcr's Avatar
Trader Rating: 46 (100%+)
The 85 rollout is a good starting point, from what I ran last year, and even most recently at IIC in Vegas. Yellows work well, if you are getting a push with the pinks.
-Alex
oldrcr is offline
Old 09-15-2009, 04:38 PM
  #1364
Canyon's Avatar
Will there be a mod tc class on Sunday? Please say yes.
Canyon is offline
Old 09-15-2009, 05:03 PM
  #1365
Trader Rating: 63 (100%+)
I'm planning to run it . Not sure about Kody ,Korey, or Kuney
The Wease is offline
